Motorola Defy XT Screen Replacement
  1. Motorola Defy XT Screen Replacement, Battery: step 1, image 1 of 1
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Screen Replacement: step 2, image 1 of 1
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Motorola Defy XT Screen Replacement: step 3, image 1 of 1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  4. Motorola Defy XT Screen Replacement, SD Card: step 4, image 1 of 1
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
  5. Motorola Defy XT Screen Replacement, Screen: step 5, image 1 of 2 Motorola Defy XT Screen Replacement, Screen: step 5, image 2 of 2
    • Use the Torx T4 screwdriver to remove the six 3 mm screws from the back case.
  6. Motorola Defy XT Screen Replacement: step 6, image 1 of 1
    • Use the plastic opening tool to pop the volume buttons off from the side of the phone.
  7. Motorola Defy XT Screen Replacement: step 7, image 1 of 1
    • Wedge the plastic opening tool between the plastic layer and the shiny front cover.
  8. Motorola Defy XT Screen Replacement: step 8, image 1 of 1
    • Slide the plastic opening tool along the edge, wedging the the two pieces apart.
    • Potential for device damage: Do not completely separate the two pieces; there are still internal components that need to be disconnected.
  9. Motorola Defy XT Screen Replacement: step 9, image 1 of 2 Motorola Defy XT Screen Replacement: step 9, image 2 of 2
    • Slide the screen out and disconnect the ribbon cable connecting the display to the motherboard by pulling straight outward.
    • Potential for device damage: Be careful when sliding out the screen because the front case and the motherboard are still connected by two other ribbon cables.
  10. Motorola Defy XT Screen Replacement: step 10, image 1 of 2 Motorola Defy XT Screen Replacement: step 10, image 2 of 2
    • Set the old screen aside and replace it with your new screen.
2 other people completed this guide.
Oscar Camacho
89 Reputation
1 Guide authored
Cal Poly, Team 2-22, Maness Spring 2013 Member of Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 59
All Time: 3,395
