Motorola Droid 2 Front Panel Replacement
  1. Motorola Droid 2 Front Panel Replacement, Battery: step 1, image 1 of 3 Motorola Droid 2 Front Panel Replacement, Battery: step 1, image 2 of 3 Motorola Droid 2 Front Panel Replacement, Battery: step 1, image 3 of 3
    • Slide the battery cover toward the bottom edge of the phone.
    • Remove the battery cover from the rear of the phone.
  2. Motorola Droid 2 Front Panel Replacement: step 2, image 1 of 2 Motorola Droid 2 Front Panel Replacement: step 2, image 2 of 2
    • Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone.
    • Remove the battery from the Droid 2.
  3. Motorola Droid 2 Front Panel Replacement, Rear Case: step 3, image 1 of 2 Motorola Droid 2 Front Panel Replacement, Rear Case: step 3, image 2 of 2
    • Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
    • Peel the ribbon off the phone.
  4. Motorola Droid 2 Front Panel Replacement: step 4, image 1 of 1
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  5. Motorola Droid 2 Front Panel Replacement: step 5, image 1 of 1
    • Use the tip of a spudger to remove the camera bezel stuck to the rear case.
  6. Motorola Droid 2 Front Panel Replacement: step 6, image 1 of 1
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  7. Motorola Droid 2 Front Panel Replacement: step 7, image 1 of 1
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  8. Motorola Droid 2 Front Panel Replacement: step 8, image 1 of 1
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  9. Motorola Droid 2 Front Panel Replacement: step 9, image 1 of 2 Motorola Droid 2 Front Panel Replacement: step 9, image 2 of 2
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  10. Motorola Droid 2 Front Panel Replacement: step 10, image 1 of 2 Motorola Droid 2 Front Panel Replacement: step 10, image 2 of 2
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
    • At this point, the button covers on the side of the phone are free and may fall out if you tip the phone upside down.
  11. Motorola Droid 2 Front Panel Replacement, Speaker: step 11, image 1 of 1
    • Carefully lift the speaker/antenna assembly up and out of the phone.
    • If you are re-assembling your phone, insert any power, camera, or volume buttons that may have fallen out at this point.
  12. Motorola Droid 2 Front Panel Replacement, Motherboard: step 12, image 1 of 3 Motorola Droid 2 Front Panel Replacement, Motherboard: step 12, image 2 of 3 Motorola Droid 2 Front Panel Replacement, Motherboard: step 12, image 3 of 3
    • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
    • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
  13. Motorola Droid 2 Front Panel Replacement: step 13, image 1 of 1
    • Peel the black rubber sheet covering the side button and display ribbon connectors on the motherboard.
  14. Motorola Droid 2 Front Panel Replacement: step 14, image 1 of 1
    • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
  15. Motorola Droid 2 Front Panel Replacement: step 15, image 1 of 1
    • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
  16. Motorola Droid 2 Front Panel Replacement: step 16, image 1 of 1
    • Use the flat end of a spudger to remove the small black plastic piece stuck to the battery connector.
  17. Motorola Droid 2 Front Panel Replacement: step 17, image 1 of 1
    • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
    • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
  18. Motorola Droid 2 Front Panel Replacement: step 18, image 1 of 1
    • Carefully lift the motherboard from the front case and lay it next to the Droid 2, minding the keypad connector that is still attached.
    • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
    • Remove the motherboard from the Droid 2.
  19. Motorola Droid 2 Front Panel Replacement, Front Panel: step 19, image 1 of 1
    • Disconnect the camera button/vibrator connector by prying it straight up off its socket on the speaker board with a spudger.
  20. Motorola Droid 2 Front Panel Replacement: step 20, image 1 of 1
    • Remove the large sticker stuck to the inner face of the battery compartment.
  21. Motorola Droid 2 Front Panel Replacement: step 21, image 1 of 2 Motorola Droid 2 Front Panel Replacement: step 21, image 2 of 2
    • Slide the phone open.
    • Lift up the edge of the black plastic rim that includes the speaker board from the side closest to the keypad.
    • Continue lifting the side of the rim until it is almost vertical, and wiggle it free from the back of the LCD assembly.
  22. Motorola Droid 2 Front Panel Replacement: step 22, image 1 of 1
    • Remove the EMI shield by releasing the clips shown with the tip of a spudger.
  23. Motorola Droid 2 Front Panel Replacement: step 23, image 1 of 1
    • Remove the five 2.5 mm T3 Torx screws along the outer edge of the slider panel.
  24. Motorola Droid 2 Front Panel Replacement: step 24, image 1 of 1
    • Slide the phone until a sixth screw is visible, as shown.
    • Remove the newly revealed 2.5 mm T3 Torx screw.
  25. Motorola Droid 2 Front Panel Replacement: step 25, image 1 of 1
    • Continue sliding the phone in the same direction, past its "closed" position, until four more screws are revealed.
    • Remove the four 2.5 mm T3 Torx screws along the outer edge of the slider.
  26. Motorola Droid 2 Front Panel Replacement: step 26, image 1 of 1
    • Return the phone to its normal "closed" position.
    • Peel the display ribbon up from the keypad's metal backing.
    • The ribbon cannot be completely removed yet, because it is attached to the back of the LCD.
    • At this point take extra caution as to not tear the ribbon cable.
  27. Motorola Droid 2 Front Panel Replacement: step 27, image 1 of 2 Motorola Droid 2 Front Panel Replacement: step 27, image 2 of 2
    • Insert a spudger between the back and front case of the display assembly, and peel the two ribbon cables off the two adhesive pads along the back case of the display assembly.
    • The location of the pads on the back case is shown. The top left corner of the case is the corner of the phone shown in the first picture.
  28. Motorola Droid 2 Front Panel Replacement: step 28, image 1 of 1
    • Use the flat end of a spudger to lift the board that contains the ambient light sensor and display data cable connector out of the screen housing.
  29. Motorola Droid 2 Front Panel Replacement: step 29, image 1 of 2 Motorola Droid 2 Front Panel Replacement: step 29, image 2 of 2
    • Use the tip of a spudger to lift the speaker out of the screen housing.
  30. Motorola Droid 2 Front Panel Replacement: step 30, image 1 of 1
    • Peel off the black tape to reveal the front panel connector.
  31. Motorola Droid 2 Front Panel Replacement: step 31, image 1 of 1
    • Remove the front panel ribbon cable from the ZIF connector on the board that is attached to the display ribbon.
  32. Motorola Droid 2 Front Panel Replacement: step 32, image 1 of 1
    • Flip the phone over and remove the front panel.
22 other people completed this guide.
3 Guide Comments
If the ribbon cable in the zif connector was not in correctly, could it cause the top 1/4th inch of the digitizer to not work?
Joseph - Reply
This guide is inaccurate.
You need a T2 torx, not a T3 torx for the Verizon Motorola Droid 2 A955. I got almost to the end, then was frustrated when my T3 wasn't working. Now i have to wait to get a new screwdriver while my phone is in pieces.
Marcus - Reply
This phone is also called the Motorola Milestone 2. On my phone the keyboard screws were T3 as stated. It did not have the rubber cover over the battery connector in step 16. I had to replace the screen so I heated the old one slightly over a gas flame to help remove the adhesive and carefully lifted it off the front panel after step 32. The new screen already had a self adhesive backing so just dropped into place. I'm not sure it was necessary to peel back the LCD ribbon in step 26 as I was not replacing the LCD?
Anthony Berkow - Reply
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 53
All Time: 27,988
