Motorola Droid 4 SIM Card Replacement
  1. Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: step 1, image 1 of 3 Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: step 1, image 2 of 3 Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: step 1, image 3 of 3
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: step 2, image 1 of 3 Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: step 2, image 2 of 3 Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers or your finger, lift the rubber SIM card cover to expose the card itself.
  3. Motorola Droid 4 SIM Card Replacement, Removing SIM card: step 3, image 1 of 3 Motorola Droid 4 SIM Card Replacement, Removing SIM card: step 3, image 2 of 3 Motorola Droid 4 SIM Card Replacement, Removing SIM card: step 3, image 3 of 3
    • While holding the cover open, use your finger to press and slide out the SIM card.
    • When reinserting the SIM card, make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
  4. Motorola Droid 4 SIM Card Replacement, Insert new SIM card: step 4, image 1 of 3 Motorola Droid 4 SIM Card Replacement, Insert new SIM card: step 4, image 2 of 3 Motorola Droid 4 SIM Card Replacement, Insert new SIM card: step 4, image 3 of 3
    • Follow the same steps in the opposite order to install the new SIM card.
    • Make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
Finish Line
Javier
533 Reputation
4 Guides authored
USF Tampa, Team 5-1, Mcgee Fall 2014 Member of USF Tampa, Team 5-1, Mcgee Fall 2014
USFT-MCGEE-F14S5G1
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 3,846
