Motorola Droid MAXX 2 Button Assembly Replacement
  1. Motorola Droid MAXX 2 Button Assembly Replacement, Battery: step 1, image 1 of 1
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Button Assembly Replacement: step 2, image 1 of 1
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Button Assembly Replacement: step 3, image 1 of 2 Motorola Droid MAXX 2 Button Assembly Replacement: step 3, image 2 of 2
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Button Assembly Replacement: step 4, image 1 of 1
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Button Assembly Replacement: step 5, image 1 of 1
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Button Assembly Replacement: step 6, image 1 of 3 Motorola Droid MAXX 2 Button Assembly Replacement: step 6, image 2 of 3 Motorola Droid MAXX 2 Button Assembly Replacement: step 6, image 3 of 3
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Button Assembly Replacement: step 7, image 1 of 1
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Button Assembly Replacement, Button Assembly: step 8, image 1 of 2 Motorola Droid MAXX 2 Button Assembly Replacement, Button Assembly: step 8, image 2 of 2
    • Peel back the orange adhesive covering the ZIF connector.
  9. Motorola Droid MAXX 2 Button Assembly Replacement: step 9, image 1 of 2 Motorola Droid MAXX 2 Button Assembly Replacement: step 9, image 2 of 2
    • Lift the black tab on the ZIF connector up.
    • Pull the ribbon cable out of the ZIF connector.
  10. Motorola Droid MAXX 2 Button Assembly Replacement: step 10, image 1 of 3 Motorola Droid MAXX 2 Button Assembly Replacement: step 10, image 2 of 3 Motorola Droid MAXX 2 Button Assembly Replacement: step 10, image 3 of 3
    • Use the plastic spudger to loosen the metal prongs that hold the button assembly onto the phone.
  11. Motorola Droid MAXX 2 Button Assembly Replacement: step 11, image 1 of 1
    • Pull the button assembly up and out of the phone.
Burke Seggerman
704 Reputation
5 Guides authored
Baylor, Team S3-G4, Williams Spring 2018 Member of Baylor, Team S3-G4, Williams Spring 2018
BU-WILLIAMS-S18S3G4
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 524
