Motorola Droid Mini Camera Replacement
  1. Motorola Droid Mini Camera Replacement, Back Case: step 1, image 1 of 2 Motorola Droid Mini Camera Replacement, Back Case: step 1, image 2 of 2
    • Pull out the volume keys using the iFixit opening tool.
  2. Motorola Droid Mini Camera Replacement: step 2, image 1 of 2 Motorola Droid Mini Camera Replacement: step 2, image 2 of 2
    • Pry off the back case gently using the iFixit opening tool.
    • Make sure to go around the entire perimeter of the case.
  3. Motorola Droid Mini Camera Replacement, Camera: step 3, image 1 of 1
    • Use a T5 Torx screwdriver to unscrew the nine silver screws from the housing frame.
  4. Motorola Droid Mini Camera Replacement: step 4, image 1 of 1
    • Carefully separate the housing frame from the motherboard.
  5. Motorola Droid Mini Camera Replacement: step 5, image 1 of 2 Motorola Droid Mini Camera Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully use the tweezers to separate the motherboard from the screen.
  6. Motorola Droid Mini Camera Replacement: step 6, image 1 of 2 Motorola Droid Mini Camera Replacement: step 6, image 2 of 2
    • Carefully use the tweezers to remove the flash motherboard.
  7. Motorola Droid Mini Camera Replacement: step 7, image 1 of 2 Motorola Droid Mini Camera Replacement: step 7, image 2 of 2
    • Use tweezers to remove the camera from the motherboard.
3 other people completed this guide.
Alec Fales
337 Reputation
2 Guides authored
USF Tampa, Team 9-2, Leahy Fall 2014 Member of USF Tampa, Team 9-2, Leahy Fall 2014
USFT-LEAHY-F14S9G2
3 Members
5 Guides authored
2 Guide Comments
What’s the OEM number of the flash motherboard ‘coz my flash died and I want to buy a new one.
Any help is much appreciated!
creativeinventiondesign - Reply
Hey where can I buy a new camera for my motorola?
Shayna W - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 13
All Time: 1,770
