Motorola Droid Mini Loudspeaker Replacement
  1. Motorola Droid Mini Loudspeaker Replacement, Back Case: step 1, image 1 of 2 Motorola Droid Mini Loudspeaker Replacement, Back Case: step 1, image 2 of 2
    • Pull out the volume keys using the iFixit opening tool.
  2. Motorola Droid Mini Loudspeaker Replacement: step 2, image 1 of 2 Motorola Droid Mini Loudspeaker Replacement: step 2, image 2 of 2
    • Pry off the back case gently using the iFixit opening tool.
    • Make sure to go around the entire perimeter of the case.
  3. Motorola Droid Mini Loudspeaker Replacement, Loudspeaker: step 3, image 1 of 2 Motorola Droid Mini Loudspeaker Replacement, Loudspeaker: step 3, image 2 of 2
    • Use the T5 screw head to unscrew the 9 silver screws from the housing frame.
    • Carefully separate the housing frame from the motherboard.
  4. Motorola Droid Mini Loudspeaker Replacement: step 4, image 1 of 2 Motorola Droid Mini Loudspeaker Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to gently push the loudspeaker out of the housing frame.
3 other people completed this guide.
Arielle
619 Reputation
3 Guides authored
USF Tampa, Team 9-2, Leahy Fall 2014 Member of USF Tampa, Team 9-2, Leahy Fall 2014
USFT-LEAHY-F14S9G2
3 Members
5 Guides authored
1 Guide Comment
Does this work with a tx1080
kaziemann123 - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 11
All Time: 2,557
