Motorola Droid RAZR Back Cover Replacement
  1. Motorola Droid RAZR Back Cover Replacement, Back Cover: step 1, image 1 of 2 Motorola Droid RAZR Back Cover Replacement, Back Cover: step 1, image 2 of 2
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Back Cover Replacement: step 2, image 1 of 3 Motorola Droid RAZR Back Cover Replacement: step 2, image 2 of 3 Motorola Droid RAZR Back Cover Replacement: step 2, image 3 of 3
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Back Cover Replacement: step 3, image 1 of 3 Motorola Droid RAZR Back Cover Replacement: step 3, image 2 of 3 Motorola Droid RAZR Back Cover Replacement: step 3, image 3 of 3
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
7 other people completed this guide.
David Hodson
155,386 Reputation
127 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 50
All Time: 14,510
