Introduction
You've shattered your screen and now you can barely use your phone without covering your hand in cuts. With this guide, you'll be able to replace that screen with a slick new one.
Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
Use tweezers to lift the black bar on top of the ZIF connector.
Pull the ribbon cable out of the connector with tweezers.
Now that there are no cables connecting the screen to the motherboard, remove the screen.
Tool used on this step:Tweezers$4.99
Remove the two 2.0mm T4 Torx screws near the top of the screen.
Remove the metal plate protecting the front camera and ear speaker with tweezers.
2 other people completed this guide.
