Motorola Droid X Motherboard Replacement
  1. Motorola Droid X Motherboard Replacement, Battery: step 1, image 1 of 2 Motorola Droid X Motherboard Replacement, Battery: step 1, image 2 of 2
    • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
  2. Motorola Droid X Motherboard Replacement: step 2, image 1 of 2 Motorola Droid X Motherboard Replacement: step 2, image 2 of 2
    • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
  3. Motorola Droid X Motherboard Replacement: step 3, image 1 of 2 Motorola Droid X Motherboard Replacement: step 3, image 2 of 2
    • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
  4. Motorola Droid X Motherboard Replacement: step 4, image 1 of 2 Motorola Droid X Motherboard Replacement: step 4, image 2 of 2
    • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
  5. Motorola Droid X Motherboard Replacement: step 5, image 1 of 1
    • The battery has been successfully removed.
  6. Motorola Droid X Motherboard Replacement, Motorola Droid X Rear Housing: step 6, image 1 of 1
    • Remove the micro SD card from its connector.
  7. Motorola Droid X Motherboard Replacement: step 7, image 1 of 3 Motorola Droid X Motherboard Replacement: step 7, image 2 of 3 Motorola Droid X Motherboard Replacement: step 7, image 3 of 3
    • Locate the seam between the back case and the end cover on the top edge of the phone.
    • Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left. Once the cover comes off set it aside
  8. Motorola Droid X Motherboard Replacement: step 8, image 1 of 3 Motorola Droid X Motherboard Replacement: step 8, image 2 of 3 Motorola Droid X Motherboard Replacement: step 8, image 3 of 3
    • Repeat step 2 on the bottom cover.
  9. Motorola Droid X Motherboard Replacement: step 9, image 1 of 3 Motorola Droid X Motherboard Replacement: step 9, image 2 of 3 Motorola Droid X Motherboard Replacement: step 9, image 3 of 3
    • Use a T5 Torx screwdriver to remove the screws in each corner of the phone.
    • The screws are very small so make sure not to lose them.
  10. Motorola Droid X Motherboard Replacement: step 10, image 1 of 2 Motorola Droid X Motherboard Replacement: step 10, image 2 of 2
    • Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
  11. Motorola Droid X Motherboard Replacement: step 11, image 1 of 2 Motorola Droid X Motherboard Replacement: step 11, image 2 of 2
    • Identify the screw located in the bottom right corner of the battery case. Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
  12. Motorola Droid X Motherboard Replacement: step 12, image 1 of 2 Motorola Droid X Motherboard Replacement: step 12, image 2 of 2
    • Locate the seam along the right edge of the phone. Use the prying tool to disconnect the two clips along the edge.
  13. Motorola Droid X Motherboard Replacement: step 13, image 1 of 3 Motorola Droid X Motherboard Replacement: step 13, image 2 of 3 Motorola Droid X Motherboard Replacement: step 13, image 3 of 3
    • Locate the two clips on the inside of the case and use the spudger tool to detach them from the case. To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
  14. Motorola Droid X Motherboard Replacement: step 14, image 1 of 2 Motorola Droid X Motherboard Replacement: step 14, image 2 of 2
    • After the clips are detached, remove the back case and set it aside.
  15. Motorola Droid X Motherboard Replacement, Motherboard: step 15, image 1 of 1
    • Remove the screws along both sides of the motherboard using a T3 Torx screwdriver. On some phones this may require a #1 Phillips Screw Driver.
  16. Motorola Droid X Motherboard Replacement: step 16, image 1 of 2 Motorola Droid X Motherboard Replacement: step 16, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully remove the white connecting wire from the motherboard using tweezers.
    • Use caution, this wire is delicate.
  17. Motorola Droid X Motherboard Replacement: step 17, image 1 of 2 Motorola Droid X Motherboard Replacement: step 17, image 2 of 2
    • Scrape away the electrical tape that covers the LCD and digitizer cable using the spudger tool or a fingernail.
  18. Motorola Droid X Motherboard Replacement: step 18, image 1 of 1
    • Use the spudger tool to pop the Digitizer cable off of the motherboard.
  19. Motorola Droid X Motherboard Replacement: step 19, image 1 of 1
    • Carefully flip the small white connector up and away from the motherboard.
  20. Motorola Droid X Motherboard Replacement: step 20, image 1 of 1
    • Gently pull the flat gold cable out from the connector.
  21. Motorola Droid X Motherboard Replacement: step 21, image 1 of 1
    • Carefully lift the motherboard and camera module up. Do not remove it from the phone!
  22. Motorola Droid X Motherboard Replacement: step 22, image 1 of 1
    • Using the spudger tool, pop the black cable connector off of the motherboard.
  23. Motorola Droid X Motherboard Replacement: step 23, image 1 of 1
    • It is to safe remove the motherboard from the phone.
Sam Johnston
576 Reputation
4 Guides authored
Cal Poly, Team 18-40, Regan Fall 2012 Member of Cal Poly, Team 18-40, Regan Fall 2012
CPSU-REGAN-F12S18G40
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 3,845
