Motorola Droid X2 Motherboard Replacement
  1. Motorola Droid X2 Motherboard Replacement, Battery: step 1, image 1 of 3 Motorola Droid X2 Motherboard Replacement, Battery: step 1, image 2 of 3 Motorola Droid X2 Motherboard Replacement, Battery: step 1, image 3 of 3
    • Slide the plastic case off of the back of the phone, exposing the battery.
  2. Motorola Droid X2 Motherboard Replacement: step 2, image 1 of 3 Motorola Droid X2 Motherboard Replacement: step 2, image 2 of 3 Motorola Droid X2 Motherboard Replacement: step 2, image 3 of 3
    • Pull up on the red battery release tab and pull the battery out of the phone.
  3. Motorola Droid X2 Motherboard Replacement, Motherboard: step 3, image 1 of 2 Motorola Droid X2 Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
    • Be careful to not strip any screws.
  4. Motorola Droid X2 Motherboard Replacement: step 4, image 1 of 3 Motorola Droid X2 Motherboard Replacement: step 4, image 2 of 3 Motorola Droid X2 Motherboard Replacement: step 4, image 3 of 3
    • Using a prying tool, snap off the front casing on the top and bottom of the phone.
    • Be careful not to lose the small rubber piece that sits over the microphone.
  5. Motorola Droid X2 Motherboard Replacement: step 5, image 1 of 2 Motorola Droid X2 Motherboard Replacement: step 5, image 2 of 2
    • Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
  6. Motorola Droid X2 Motherboard Replacement: step 6, image 1 of 3 Motorola Droid X2 Motherboard Replacement: step 6, image 2 of 3 Motorola Droid X2 Motherboard Replacement: step 6, image 3 of 3
    • Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
  7. Motorola Droid X2 Motherboard Replacement: step 7, image 1 of 3 Motorola Droid X2 Motherboard Replacement: step 7, image 2 of 3 Motorola Droid X2 Motherboard Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, remove the white wire at the top of the phone near the camera.
  8. Motorola Droid X2 Motherboard Replacement: step 8, image 1 of 2 Motorola Droid X2 Motherboard Replacement: step 8, image 2 of 2
    • Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
  9. Motorola Droid X2 Motherboard Replacement: step 9, image 1 of 2 Motorola Droid X2 Motherboard Replacement: step 9, image 2 of 2
    • Using tweezers, removed the white electrical tape on the motherboard.
  10. Motorola Droid X2 Motherboard Replacement: step 10, image 1 of 2 Motorola Droid X2 Motherboard Replacement: step 10, image 2 of 2
    • Using the plastic opening tool, lift up to remove the connector.
  11. Motorola Droid X2 Motherboard Replacement: step 11, image 1 of 2 Motorola Droid X2 Motherboard Replacement: step 11, image 2 of 2
    • Using a pry tool, lift the jawbone connector.
  12. Motorola Droid X2 Motherboard Replacement: step 12, image 1 of 2 Motorola Droid X2 Motherboard Replacement: step 12, image 2 of 2
    • Using tweezers, carefully disconnect the cable connector by pulling the cable out.
  13. Motorola Droid X2 Motherboard Replacement: step 13, image 1 of 3 Motorola Droid X2 Motherboard Replacement: step 13, image 2 of 3 Motorola Droid X2 Motherboard Replacement: step 13, image 3 of 3
    • Use a spudger to disconnect the cable connector.
  14. Motorola Droid X2 Motherboard Replacement: step 14, image 1 of 3 Motorola Droid X2 Motherboard Replacement: step 14, image 2 of 3 Motorola Droid X2 Motherboard Replacement: step 14, image 3 of 3
    • Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
Aaron Mak
658 Reputation
4 Guides authored
UMass Dartmouth, Team 4-3, Miles Fall 2014 Member of UMass Dartmouth, Team 4-3, Miles Fall 2014
UMASSD-MILES-F14S4G3
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 798
