Motorola Edge 5G UW (2022) Vibration Motor Replacement
  1. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the SIM card tray: step 1, image 1 of 3 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the SIM card tray: step 1, image 2 of 3 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the SIM card tray: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Insert a SIM eject tool, bit, or straightened paperclip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the sim card tray hole to eject the SIM card tray.
    • Use your fingers or tweezers to remove the SIM card tray.
  2. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Heat the left edge: step 2, image 1 of 1
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's left edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the back cover and internal battery are both susceptible to heat damage.
  3. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Separate the left adhesive: step 3, image 1 of 3 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Separate the left adhesive: step 3, image 2 of 3 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Separate the left adhesive: step 3, image 3 of 3
    • Apply a suction cup to the back of the phone, as close to the bottom left corner as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the midframe on the left edge.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  4. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Slice the left adhesive: step 4, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Slice the left adhesive: step 4, image 2 of 2
    • Slide the pick along the left edge of the phone to slice the adhesive securing the back cover to the frame.
    • Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
  5. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Heat the top edge: step 5, image 1 of 1
    • Apply a heated iOpener to the back cover's top edge for two minutes.
  6. Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 6, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 6, image 2 of 2
    • Rotate the pick around the top left corner to slice the adhesive.
  7. Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 7, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 7, image 2 of 2
    • Slide the pick along the top edge to slice the adhesive.
    • Leave the opening pick inserted in the top right corner to prevent the adhesive from resealing.
  8. Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 8, image 1 of 1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  9. Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 9, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 9, image 2 of 2
    • Rotate the pick around the top right corner to slice the adhesive.
  10. Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 10, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 10, image 2 of 2
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from resealing.
  11. Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 11, image 1 of 1
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
  12. Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 12, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 12, image 2 of 2
    • Rotate the pick around the bottom right corner to slice the adhesive.
  13. Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 13, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 13, image 2 of 2
    • Slide the pick along the bottom edge to slice the adhesive.
  14. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Heat the camera adhesive: step 14, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Heat the camera adhesive: step 14, image 2 of 2
    • There's a significant amount of adhesive to the right of the cameras that secures the back cover to the motherboard cover.
    • Apply a heated iOpener to the right of the cameras for two minutes.
  15. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Slice the adhesive around the camera: step 15, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Slice the adhesive around the camera: step 15, image 2 of 2
    • Insert an opening pick between the back cover and motherboard cover on the top right edge.
    • Gently pull up on the back cover while sliding the opening pick back and forth along the right side of the cameras to slice the adhesive.
    • The back cover should detach from the phone at this point.
  16. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the back cover: step 16, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the back cover: step 16, image 2 of 2
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to replace the back cover adhesive.
  17. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Unfasten the motherboard cover: step 17, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Unfasten the motherboard cover: step 17, image 2 of 2
    • Use a Phillips screwdriver to remove the 13 4 mm screws securing the motherboard cover.
  18. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Release the motherboard cover clips: step 18, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Release the motherboard cover clips: step 18, image 2 of 2
    • Insert a spudger between the motherboard cover and midframe on the top right edge of the phone.
    • Pry up with the spudger to release the clips securing the motherboard cover.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
  19. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the motherboard cover: step 19, image 1 of 3 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the motherboard cover: step 19, image 2 of 3 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the motherboard cover: step 19, image 3 of 3
    • Gently pull the motherboard cover up and away from the phone and remove it.
    • Don't pull quickly or forcefully, as the heat spreader very loosely secures the motherboard cover to the battery.
  20. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Disconnect the battery: step 20, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Disconnect the battery: step 20, image 2 of 2
    • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Unfasten the daughterboard cover: step 21, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Unfasten the daughterboard cover: step 21, image 2 of 2
    • Use a Phillips screwdriver to remove the six 4 mm screws that secure the daughterboard cover.
  22. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the daughterboard cover: step 22, image 1 of 3 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the daughterboard cover: step 22, image 2 of 3 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the daughterboard cover: step 22, image 3 of 3
    Buy
    • Use your fingers or tweezers to lift the daughterboard cover up and towards the top edge of the phone to remove it.
    • Be gentle when lifting, as a small heat spreader loosely connects the daughterboard cover to the battery.
  23. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Disconnect the interconnect cable: step 23, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Disconnect the interconnect cable: step 23, image 2 of 2
    • Use the pointed end of a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
  24. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Disconnect the antenna cable: step 24, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Disconnect the antenna cable: step 24, image 2 of 2
    • Take care not to puncture the battery with your tweezers—a punctured battery may leak dangerous chemicals or cause a fire.
    • Use tweezers to grip the top and bottom of the white antenna's coaxial connector, as close to the connector head as possible.
    • Lift straight up to disconnect the cable.
    • Be gentle when disconnecting the cable, as it's very easy to tear the socket from the daughterboard.
    • To re-attach coaxial connectors like this one, hold the connectors in place and gently press them straight down with your finger or the pointed end of a spudger.
  25. Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 25, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 25, image 2 of 2
    • Use tweezers or your fingers to gently pull the white antenna cable up and towards the right edge of the phone until it's freed from the clip securing it to the daughterboard.
    • During reassembly, make sure to put the cable back in its clip on the daughterboard.
  26. Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 26, image 1 of 3 Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 26, image 2 of 3 Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 26, image 3 of 3
    • Use the same technique to disconnect and loosen the blue and black antenna cables.
    • During reassembly, make sure to put the cables back in their clips on the daughterboard.
  27. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Unfasten the daughterboard: step 27, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Unfasten the daughterboard: step 27, image 2 of 2
    • Use a Phillips screwdriver to remove the 3 mm screw securing the daughterboard.
  28. Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 28, image 1 of 2 Motorola Edge 5G UW (2022) Vibration Motor Replacement: step 28, image 2 of 2
    • Before you perform this step, be sure you’ve ejected the SIM tray.
    • Use your fingers or tweezers to pull the daughterboard up and towards the top edge to remove it.
    • During reassembly, make sure that all of the cables that connect to the daughterboard (interconnect and antennas) are out of they way so they don't get stuck under the daughterboard when it's reinserted.
  29. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Apply isopropoyl alcohol: step 29, image 1 of 1
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the vibration motor and its contact pad to loosen the adhesive securing them.
    • Let the isopropyl alcohol soak for one minute.
  30. Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the vibration motor: step 30, image 1 of 3 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the vibration motor: step 30, image 2 of 3 Motorola Edge 5G UW (2022) Vibration Motor Replacement, Remove the vibration motor: step 30, image 3 of 3
    Buy
    • Insert the pointed end of a spudger in the gap between the vibration motor and frame.
    • Pry up with the spudger to dislodge the vibration motor.
    • The vibration motor's flex cable is very fragile. Work slowly to prevent tearing the cable.
    • Use tweezers or your fingers to remove the vibration motor.
    • If there's any alcohol remaining, use a lint-free cloth to wipe it up or allow the alcohol to dry off before installing a new vibration motor.
    • Apply new adhesive to your vibration motor before installing it in the frame.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order.
Spencer Day
59,654 Reputation
430 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 126
