Motorola Edge Motherboard Cover Replacement
Jennifer Berg
Jennifer Berg and 4 other contributors
Last updated on March 21, 2025
30 - 45 minutes
Moderate
Introduction
Go to step 1
Follow this guide to remove and replace the battery on a Motorola Edge.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
This guide is also useful for replacing the flash, which is part of the motherboard cover assembly.
Parts
Tools
Show more…
  1. Motorola Edge Motherboard Cover Replacement, Heat the bottom edge: step 1, image 1 of 1
    • Completely power off your phone before you begin.
    • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge Motherboard Cover Replacement, Separate the bottom adhesive: step 2, image 1 of 3 Motorola Edge Motherboard Cover Replacement, Separate the bottom adhesive: step 2, image 2 of 3 Motorola Edge Motherboard Cover Replacement, Separate the bottom adhesive: step 2, image 3 of 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge Motherboard Cover Replacement, Slice the bottom adhesive: step 3, image 1 of 3 Motorola Edge Motherboard Cover Replacement, Slice the bottom adhesive: step 3, image 2 of 3 Motorola Edge Motherboard Cover Replacement, Slice the bottom adhesive: step 3, image 3 of 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Motorola Edge Motherboard Cover Replacement, Heat the right edge: step 4, image 1 of 1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  5. Motorola Edge Motherboard Cover Replacement, Separate the corner adhesive: step 5, image 1 of 3 Motorola Edge Motherboard Cover Replacement, Separate the corner adhesive: step 5, image 2 of 3 Motorola Edge Motherboard Cover Replacement, Separate the corner adhesive: step 5, image 3 of 3
    • Rotate the opening pick around the bottom-right corner of the phone.
  6. Motorola Edge Motherboard Cover Replacement, Separate the right adhesive: step 6, image 1 of 3 Motorola Edge Motherboard Cover Replacement, Separate the right adhesive: step 6, image 2 of 3 Motorola Edge Motherboard Cover Replacement, Separate the right adhesive: step 6, image 3 of 3
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the right edge of the phone to separate the adhesive.
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
  7. Motorola Edge Motherboard Cover Replacement, Remove the back cover: step 7, image 1 of 3 Motorola Edge Motherboard Cover Replacement, Remove the back cover: step 7, image 2 of 3 Motorola Edge Motherboard Cover Replacement, Remove the back cover: step 7, image 3 of 3
    • Remove the back cover, taking care not to damage the components inside the phone.
  8. Motorola Edge Motherboard Cover Replacement, Remove the motherboard's screws: step 8, image 1 of 1
    • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
  9. Motorola Edge Motherboard Cover Replacement, Remove the motherboard cover: step 9, image 1 of 3 Motorola Edge Motherboard Cover Replacement, Remove the motherboard cover: step 9, image 2 of 3 Motorola Edge Motherboard Cover Replacement, Remove the motherboard cover: step 9, image 3 of 3
    Tool used on this step:
    • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
    • The motherboard cover also contains the phone's flash.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Jennifer Berg
2,751 Reputation
24 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 186
