Motorola MOTO W755 Cell Phone Main Logic Board Replacement
  1. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Battery: step 1, image 1 of 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Battery: step 1, image 2 of 2
    • Using your finger, press down on the clip holding the back cover on
    • Pull the back cover off.
  2. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: step 2, image 1 of 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: step 2, image 2 of 2
    • Place thumb and index finger in the spaces on either side of the battery.
    • Pull battery out.
  3. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Main Logic Board: step 3, image 1 of 1
    • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
  4. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: step 4, image 1 of 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: step 4, image 2 of 2
    • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
    • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
  5. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: step 5, image 1 of 3 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: step 5, image 2 of 3 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: step 5, image 3 of 3
    • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
    • Slide the opening tool around the phone clockwise until you reach the audio port.
    • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
  6. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: step 6, image 1 of 1
    • Remove the plastic covering completely from the body of the phone.
  7. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: step 7, image 1 of 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: step 7, image 2 of 2
    • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
    • Remove the main logic board.
C Miller
56 Reputation
3 Guides authored
Cal Poly, Team 1-3, Regan SU 2012 Member of Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,524
