Motorola Moto 360 3rd Gen Battery Replacement
  1. Motorola Moto 360 3rd Gen Battery Replacement, Lower Case: step 1, image 1 of 2 Motorola Moto 360 3rd Gen Battery Replacement, Lower Case: step 1, image 2 of 2
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Use a T4 Torx screwdriver to remove the four 4.2 mm screws securing the lower case.
    • Gently pry the case open with a halberd spudger if the case will not release after removing the bolts.
    • Do not remove the lower case completely yet; this could damage cables connected to the lower case.
  2. Motorola Moto 360 3rd Gen Battery Replacement: step 2, image 1 of 1
    • Raise the cover without straining the connected ribbon cable.
    • Disconnect the ribbon cable from the motherboard with a halberd spudger.
  3. Motorola Moto 360 3rd Gen Battery Replacement, Battery: step 3, image 1 of 3 Motorola Moto 360 3rd Gen Battery Replacement, Battery: step 3, image 2 of 3 Motorola Moto 360 3rd Gen Battery Replacement, Battery: step 3, image 3 of 3
    Halberd Spudger
    $2.99
    Buy
    • Use a halberd spudger to lift the three flat-top connectors straight up to disconnect them.
    • Do not disconnect the battery (bottom-left) cable yet.
  4. Motorola Moto 360 3rd Gen Battery Replacement: step 4, image 1 of 3 Motorola Moto 360 3rd Gen Battery Replacement: step 4, image 2 of 3 Motorola Moto 360 3rd Gen Battery Replacement: step 4, image 3 of 3
    • Gently remove the motherboard using the halberd spudger.
    • The best area to pry is at the bottom of the motherboard, right under one of the ribbons that was just disconnected.
  5. Motorola Moto 360 3rd Gen Battery Replacement: step 5, image 1 of 3 Motorola Moto 360 3rd Gen Battery Replacement: step 5, image 2 of 3 Motorola Moto 360 3rd Gen Battery Replacement: step 5, image 3 of 3
    • Flip the motherboard over so the battery is facing upwards.
    • Gently pry the battery out of the motherboard housing.
    • The best area to pry is at the top-left corner.
    • Take care not to puncture, bend, or twist the battery while removing it. A damaged battery can start a fire!
    • Disconnect the battery ribbon from the motherboard using the spudger tool.
  6. Motorola Moto 360 3rd Gen Battery Replacement: step 6, image 1 of 2 Motorola Moto 360 3rd Gen Battery Replacement: step 6, image 2 of 2
    • Connect the new battery's ribbon to the motherboard.
    • Insert the new battery in the same orientation the old battery previously had.
To reassemble your device, follow these instructions in reverse order carefully.
3 Comments
Excellent guide, thanks. Any luck in finding a replacement battery?
Emiliano Brunetti - Reply
Same. No idea where to get a replacement battery
Chandler Prude - Reply
Great article but without a replacement battery source its pretty pointless.
Scott L - Reply
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 53
All Time: 781
