Motorola Moto 360 3rd Gen Charging Coil Replacement
  1. Motorola Moto 360 3rd Gen Charging Coil Replacement, Lower Case: step 1, image 1 of 2 Motorola Moto 360 3rd Gen Charging Coil Replacement, Lower Case: step 1, image 2 of 2
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Use a T4 Torx screwdriver to remove the four 4.2 mm screws securing the lower case.
    • Gently pry the case open with a halberd spudger if the case will not release after removing the bolts.
    • Do not remove the lower case completely yet; this could damage cables connected to the lower case.
  2. Motorola Moto 360 3rd Gen Charging Coil Replacement: step 2, image 1 of 1
    • Raise the cover without straining the connected ribbon cable.
    • Disconnect the ribbon cable from the motherboard with a halberd spudger.
  3. Motorola Moto 360 3rd Gen Charging Coil Replacement, Charging Coil: step 3, image 1 of 3 Motorola Moto 360 3rd Gen Charging Coil Replacement, Charging Coil: step 3, image 2 of 3 Motorola Moto 360 3rd Gen Charging Coil Replacement, Charging Coil: step 3, image 3 of 3
    • Gently wedge a spudger underneath the charging coil ribbon.
    • Carefully pry the charging coil up and remove it from the assembly.
  4. Motorola Moto 360 3rd Gen Charging Coil Replacement: step 4, image 1 of 2 Motorola Moto 360 3rd Gen Charging Coil Replacement: step 4, image 2 of 2
    • Place the new charging coil in the same orientation as the one previously removed.
    • Attach the charging coil ribbon cable to the watch motherboard.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 174
