Motorola Moto 360 O-Ring Replacement
  1. Motorola Moto 360 O-Ring Replacement, Rear Cover: step 1, image 1 of 1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 O-Ring Replacement: step 3, image 1 of 2 Motorola Moto 360 O-Ring Replacement: step 3, image 2 of 2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 O-Ring Replacement: step 4, image 1 of 1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
  4. Motorola Moto 360 O-Ring Replacement, O-Ring: step 5, image 1 of 2 Motorola Moto 360 O-Ring Replacement, O-Ring: step 5, image 2 of 2
    • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
  5. Motorola Moto 360 O-Ring Replacement: step 6, image 1 of 1
    • Pinch the green rubber O-Ring and slide it off of the watch.
    • The O-Ring is delicate and is easily severed. Use care around sharp objects.
2 other people completed this guide.
Jake Steinorth
149 Reputation
1 Guide authored
Cal Poly, Team 17-32, Amido Winter 2015 Member of Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Members
18 Guides authored
3 Comments
Where can you get your hands on a replacement o'ring?!
James S - Reply
I broke my o-ring. Any ideas where I could get a raplacement?
Simon Hölz - Reply
i think you should not take the o ring. i was replaceing the battery without take the O ring
cahyanto emanuel nur - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 9
All Time: 2,748
