Introduction
Replacing the touch screen requires you to completely disassemble the device. Use caution when handling the shattered screen.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
24 other people completed this guide.
