Motorola Moto E4 Plus Back Plate and Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Motorola Moto E4 Plus Back Plate and Battery Replacement, Back Plate and Battery: step 1, image 1 of 2 Motorola Moto E4 Plus Back Plate and Battery Replacement, Back Plate and Battery: step 1, image 2 of 2
    • Insert the spudger into the notch on the corner of the phone and lift up to remove the back case.
  2. Motorola Moto E4 Plus Back Plate and Battery Replacement: step 2, image 1 of 1
    • Use the T4 Torx Screwdriver to remove the 17 3.2 mm screws in the back panel covering the battery.
  3. Motorola Moto E4 Plus Back Plate and Battery Replacement: step 3, image 1 of 3 Motorola Moto E4 Plus Back Plate and Battery Replacement: step 3, image 2 of 3 Motorola Moto E4 Plus Back Plate and Battery Replacement: step 3, image 3 of 3
    • Lift up and remove the back panel.
  4. Motorola Moto E4 Plus Back Plate and Battery Replacement: step 4, image 1 of 2 Motorola Moto E4 Plus Back Plate and Battery Replacement: step 4, image 2 of 2
    • After removing the back panel, use the spudger to lift and detach the Battery Flux Cable from the Motherboard.
  5. Motorola Moto E4 Plus Back Plate and Battery Replacement: step 5, image 1 of 3 Motorola Moto E4 Plus Back Plate and Battery Replacement: step 5, image 2 of 3 Motorola Moto E4 Plus Back Plate and Battery Replacement: step 5, image 3 of 3
    • Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape.
After completing this guide, calibrate your newly-installed battery.
10 other people completed this guide.
Jack Haseman
1,396 Reputation
6 Guides authored
Baylor, Team S3-G2, Williams Spring 2018 Member of Baylor, Team S3-G2, Williams Spring 2018
BU-WILLIAMS-S18S3G2
4 Members
13 Guides authored
3 Comments
my moto e4 plus screen is freezing , how can we unfreeze please advise
rajamfaisal - Reply
This is the only tutorial that looks like my phone inside, even tho they’re all supposed to be Moto E4 Plus. All the ones on YouTube look different, screws in different places, etc.
Brad Rathernotsay - Reply
Hi Brad,
Motorola released a few variants of Moto E4s. You can compare phone’s model number to figure out exactly which model you have. We unfortunately don’t have all the Motorola guides covered at this point, but we’re working on it!
Arthur Shi -
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 5,791
