Motorola Moto E4 Plus Daughterboard Replacement
  1. Motorola Moto E4 Plus Daughterboard Replacement, Remove the back cover: step 1, image 1 of 3 Motorola Moto E4 Plus Daughterboard Replacement, Remove the back cover: step 1, image 2 of 3 Motorola Moto E4 Plus Daughterboard Replacement, Remove the back cover: step 1, image 3 of 3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Daughterboard Replacement: step 2, image 1 of 2 Motorola Moto E4 Plus Daughterboard Replacement: step 2, image 2 of 2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Daughterboard Replacement, Remove the midframe screws: step 3, image 1 of 1
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Daughterboard Replacement, Release the midframe clips: step 4, image 1 of 2 Motorola Moto E4 Plus Daughterboard Replacement, Release the midframe clips: step 4, image 2 of 2
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Daughterboard Replacement, Remove the midframe: step 5, image 1 of 2 Motorola Moto E4 Plus Daughterboard Replacement, Remove the midframe: step 5, image 2 of 2
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the battery: step 6, image 1 of 2 Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the battery: step 6, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the antenna: step 7, image 1 of 2 Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the antenna: step 7, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the antenna cable from its daughterboard socket.
  8. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the daughterboard connectors: step 8, image 1 of 3 Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the daughterboard connectors: step 8, image 2 of 3 Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the daughterboard connectors: step 8, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the interconnect cable from its daughterboard socket.
    • Pry up and disconnect the fingerprint sensor cable next to it from the daughterboard.
  9. Motorola Moto E4 Plus Daughterboard Replacement, Remove the daughterboard screws: step 9, image 1 of 1
    • Remove the two 3.2 mm long T3 screws securing the daughterboard.
  10. Motorola Moto E4 Plus Daughterboard Replacement, Loosen the daughterboard: step 10, image 1 of 2 Motorola Moto E4 Plus Daughterboard Replacement, Loosen the daughterboard: step 10, image 2 of 2
    • Insert the point of a spudger under the bottom right corner of the daughterboard and pry up to loosen the daughterboard.
  11. Motorola Moto E4 Plus Daughterboard Replacement, Loosen the vibration motor: step 11, image 1 of 2 Motorola Moto E4 Plus Daughterboard Replacement, Loosen the vibration motor: step 11, image 2 of 2
    • Insert the point of a spudger underneath the vibration motor and pry upwards to loosen it.
  12. Motorola Moto E4 Plus Daughterboard Replacement, Remove the daughterboard: step 12, image 1 of 2 Motorola Moto E4 Plus Daughterboard Replacement, Remove the daughterboard: step 12, image 2 of 2
    • Grasp the daughterboard by the edges and lift it out of its recess.
    • Remove the daughterboard. The vibration motor will be attached to it.
2 other people completed this guide.
Arthur Shi
257,468 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,503
