Motorola Moto E4 Plus Earpiece Replacement
Jack Haseman
Jack Haseman and 4 other contributors
Last updated on August 30, 2019
10 - 15 minutes
Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1
For the official, updated iFixit guide, click here. This guide is archived for historical purposes.
This guide is helpful for users who are having difficulty with sound quality, clarity, or volume while taking a phone call.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
  1. Motorola Moto E4 Plus Earpiece Replacement, Back Plate and Battery: step 1, image 1 of 2 Motorola Moto E4 Plus Earpiece Replacement, Back Plate and Battery: step 1, image 2 of 2
    • Insert the spudger into the notch on the corner of the phone and lift up to remove the back case.
  2. Motorola Moto E4 Plus Earpiece Replacement: step 2, image 1 of 1
    • Use the T4 Torx Screwdriver to remove the 17 3.2 mm screws in the back panel covering the battery.
  3. Motorola Moto E4 Plus Earpiece Replacement: step 3, image 1 of 3 Motorola Moto E4 Plus Earpiece Replacement: step 3, image 2 of 3 Motorola Moto E4 Plus Earpiece Replacement: step 3, image 3 of 3
    • Lift up and remove the back panel.
  4. Motorola Moto E4 Plus Earpiece Replacement: step 4, image 1 of 2 Motorola Moto E4 Plus Earpiece Replacement: step 4, image 2 of 2
    • After removing the back panel, use the spudger to lift and detach the Battery Flux Cable from the Motherboard.
  5. Motorola Moto E4 Plus Earpiece Replacement: step 5, image 1 of 3 Motorola Moto E4 Plus Earpiece Replacement: step 5, image 2 of 3 Motorola Moto E4 Plus Earpiece Replacement: step 5, image 3 of 3
    • Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape.
  6. Motorola Moto E4 Plus Earpiece Replacement, Rear Camera: step 6, image 1 of 2 Motorola Moto E4 Plus Earpiece Replacement, Rear Camera: step 6, image 2 of 2
    Tool used on this step:
    • Use a pair of tweezers to peel up the copper tape that covers the rear camera flex connector.
    • Fold the copper tape out of the way.
  7. Motorola Moto E4 Plus Earpiece Replacement: step 7, image 1 of 2 Motorola Moto E4 Plus Earpiece Replacement: step 7, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the rear camera flex cable.
  8. Motorola Moto E4 Plus Earpiece Replacement: step 8, image 1 of 1
    • Carefully remove the rear camera with a pair of tweezers.
  9. Motorola Moto E4 Plus Earpiece Replacement, Motherboard: step 9, image 1 of 1
    • Use the T4 Torx Screwdriver to remove the 2 3.2 mm screws circled in the image.
  10. Motorola Moto E4 Plus Earpiece Replacement: step 10, image 1 of 2 Motorola Moto E4 Plus Earpiece Replacement: step 10, image 2 of 2
    • Use the Spudger to lift up and detach the Main Flex Cable from the Motherboard.
  11. Motorola Moto E4 Plus Earpiece Replacement: step 11, image 1 of 2 Motorola Moto E4 Plus Earpiece Replacement: step 11, image 2 of 2
    • Use the Spudger to lift up and detach the LCD Screen Flex Cable from the Motherboard.
  12. Motorola Moto E4 Plus Earpiece Replacement: step 12, image 1 of 1
    • Use the Plastic Spudger to lift up and detach the Signal Flex Cable from the Motherboard. The Signal Flex Cable should still be attached to the body of the phone.
  13. Motorola Moto E4 Plus Earpiece Replacement: step 13, image 1 of 2 Motorola Moto E4 Plus Earpiece Replacement: step 13, image 2 of 2
    • Use the Spudger to lift up and remove the Motherboard from the phone.
  14. Motorola Moto E4 Plus Earpiece Replacement, Earpiece Speaker: step 14, image 1 of 3 Motorola Moto E4 Plus Earpiece Replacement, Earpiece Speaker: step 14, image 2 of 3 Motorola Moto E4 Plus Earpiece Replacement, Earpiece Speaker: step 14, image 3 of 3
    • Use the Plastic Spudger to remove the Earpiece Speaker from the phone.
4 other people completed this guide.
Jack Haseman
1,396 Reputation
6 Guides authored
Baylor, Team S3-G2, Williams Spring 2018 Member of Baylor, Team S3-G2, Williams Spring 2018
BU-WILLIAMS-S18S3G2
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 995
