Motorola Moto E6 Charging Dock Replacement
  1. Motorola Moto E6 Charging Dock Replacement, Back Cover: step 1, image 1 of 2 Motorola Moto E6 Charging Dock Replacement, Back Cover: step 1, image 2 of 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Charging Dock Replacement, Battery: step 2, image 1 of 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Charging Dock Replacement, Charging Dock: step 3, image 1 of 1
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  4. Motorola Moto E6 Charging Dock Replacement: step 4, image 1 of 1
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  5. Motorola Moto E6 Charging Dock Replacement: step 5, image 1 of 1
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
  6. Motorola Moto E6 Charging Dock Replacement: step 6, image 1 of 1
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
6 other people completed this guide.
Matthew Zelten
471 Reputation
3 Guides authored
Cal Poly, Team S2-G3, White Winter 2020 Member of Cal Poly, Team S2-G3, White Winter 2020
CPSU-WHITE-W20S2G3
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 3,072
