Motorola Moto E6 Speaker Replacement
  1. Motorola Moto E6 Speaker Replacement, Back Cover: step 1, image 1 of 2 Motorola Moto E6 Speaker Replacement, Back Cover: step 1, image 2 of 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Speaker Replacement, Battery: step 2, image 1 of 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Speaker Replacement, Speaker: step 3, image 1 of 1
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Speaker Replacement: step 4, image 1 of 1
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Speaker Replacement: step 5, image 1 of 3 Motorola Moto E6 Speaker Replacement: step 5, image 2 of 3 Motorola Moto E6 Speaker Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, lift the speaker from the motherboard located at the top of the device.
    • When replacing with a new component, make sure the clips are facing towards the user.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,233
