Motorola Moto G 1st Generation Speaker Replacement
  1. Careful: steps 1-3 are sourced from a guide that's marked as in-progress.
    Motorola Moto G 1st Generation Speaker Replacement, Rear Panel: step 1, image 1 of 3 Motorola Moto G 1st Generation Speaker Replacement, Rear Panel: step 1, image 2 of 3 Motorola Moto G 1st Generation Speaker Replacement, Rear Panel: step 1, image 3 of 3
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
  2. Motorola Moto G 1st Generation Speaker Replacement, Removing the Screws: step 2, image 1 of 1
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
  3. Motorola Moto G 1st Generation Speaker Replacement, Removing the Battery Cover: step 3, image 1 of 2 Motorola Moto G 1st Generation Speaker Replacement, Removing the Battery Cover: step 3, image 2 of 2
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Motorola Moto G 1st Generation Speaker Replacement, Removing the Speaker: step 4, image 1 of 3 Motorola Moto G 1st Generation Speaker Replacement, Removing the Speaker: step 4, image 2 of 3 Motorola Moto G 1st Generation Speaker Replacement, Removing the Speaker: step 4, image 3 of 3
    • Use the plastic opening tool to remove the Speaker from the protective cover.
2 other people completed this guide.
Radostin Lobodov
2,904 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 2,188
