Introduction
By following this guide, you'll be able to remove and replace the speakers in your Moto G, in the event that they are malfunctioning. This repair is not difficult, but it may take some time, as you have to dig through a few layers to reach the speakers. All you'll need is a T5 Torx screwdriver and a plastic opening tool.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
Work your way down the sides to avoid cracking the rear cover.
Using a plastic opening tool or tweezers, disconnect the SIM/SD card reader at the top of the phone.
Disconnect the battery connector by prying it off of the motherboard.
Disconnect the vibration motor by prying its connector off of the motherboard.
This is where you will find the two speakers, after you have taken off the motherboard.
16 other people completed this guide.
10 Comments
Same problem happened to me when I replaced the screen, had to remove the speaker and when I put it back the upper (left) didn't work and the lower (right) had terrible distortion noise. playing a little with the upper speaker location made it work but with noise as well.
The phone is useless without this speaker, it's pretty shame that nobody pays attention to this point in their guides.
Have you fixed your speakers? Did you at least discovered why it happened?
I had a similar problem after replacing my battery. After I put the phone back together, my bottom speaker was not working. I went ahead and ordered a speaker to replace the one that was not working, and it still didn't work. Knowing that my top speaker was working okay, I replaced the top speaker to see if the new one I received was working, and it didn't work on top either. As a matter of fact, I put back the original top speaker that was working okay, and now it doesn't work. So now neither one of them are working. I have to use earphones to hear my phone. I don't know what happened. The instructions to replace the speakers are not that difficult.
Does anyone have any suggestions on what I should do? I'm not ready to give up my phone just yet.
Betsey -
To corroborate with the other commenters: removing the motherboard is unnecessary. The speakers are only held in with a small ring of adhesive, which can easily be pried out. Additionally, the two speakers are identical.
