Motorola Moto G Play (2021) Back Cover Replacement
  1. Motorola Moto G Play (2021) Back Cover Replacement, Heat the left edge: step 1, image 1 of 1
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the left edge of the cover for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto G Play (2021) Back Cover Replacement, Insert an opening pick: step 2, image 1 of 3 Motorola Moto G Play (2021) Back Cover Replacement, Insert an opening pick: step 2, image 2 of 3 Motorola Moto G Play (2021) Back Cover Replacement, Insert an opening pick: step 2, image 3 of 3
    • Apply a suction cup to the back cover, as close to the center of the left edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  3. Motorola Moto G Play (2021) Back Cover Replacement, Slice the right adhesive: step 3, image 1 of 3 Motorola Moto G Play (2021) Back Cover Replacement, Slice the right adhesive: step 3, image 2 of 3 Motorola Moto G Play (2021) Back Cover Replacement, Slice the right adhesive: step 3, image 3 of 3
    • Slide your opening pick back and forth along the left edge to slice through the adhesive.
    • Leave the pick in at the bottom left corner to prevent the adhesive from resealing.
  4. Motorola Moto G Play (2021) Back Cover Replacement, Slice the bottom adhesive: step 4, image 1 of 2 Motorola Moto G Play (2021) Back Cover Replacement, Slice the bottom adhesive: step 4, image 2 of 2
    • Insert and slide a second opening pick to the bottom right corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
    • Repeat this process for the right and top edges of the cover.
  5. Motorola Moto G Play (2021) Back Cover Replacement, Dislodge the fingerprint reader: step 5, image 1 of 3 Motorola Moto G Play (2021) Back Cover Replacement, Dislodge the fingerprint reader: step 5, image 2 of 3 Motorola Moto G Play (2021) Back Cover Replacement, Dislodge the fingerprint reader: step 5, image 3 of 3
    • The fingerprint reader is connected to the motherboard by a fragile cable. You must free it before pulling the cover off.
    • Grab and lift the bottom edge of the cover.
    • As you lift the back cover, press and unstick the fingerprint reader from it.
  6. Motorola Moto G Play (2021) Back Cover Replacement, Remove the back cover: step 6, image 1 of 3 Motorola Moto G Play (2021) Back Cover Replacement, Remove the back cover: step 6, image 2 of 3 Motorola Moto G Play (2021) Back Cover Replacement, Remove the back cover: step 6, image 3 of 3
    • Grab and remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
Clay Eickemeyer
69,494 Reputation
453 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 95
All Time: 2,137
