Motorola Moto G3 Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Motorola Moto G3 Battery Replacement, Prerequisite Guide: step 1, image 1 of 2 Motorola Moto G3 Battery Replacement, Prerequisite Guide: step 1, image 2 of 2
    • Use the plastic opening tool to open the back cover as shown in the photo.
  2. Motorola Moto G3 Battery Replacement: step 2, image 1 of 1
    • Heat an iOpener in the microwave for 30 seconds.
    • Place the heated iOpener on all four edges of the screen for approximately 2 minutes.
  3. Motorola Moto G3 Battery Replacement: step 3, image 1 of 1
    • Apply the plastic opening tool on the edge of the screen near the front camera.
    • After creating enough space, allow the opening tool to be inserted on the side of the phone.
    • Create another space on the other side of the screen.
    • Leave the opening tool inserted.
    • Carefully apply the larger plastic opening tool by sliding it through the longer edge of the screen.
  4. Motorola Moto G3 Battery Replacement: step 4, image 1 of 3 Motorola Moto G3 Battery Replacement: step 4, image 2 of 3 Motorola Moto G3 Battery Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • A strip will be attached to the motherboard as shown.
    • Using tweezers, carefully detach the strip from the motherboard.
  5. Motorola Moto G3 Battery Replacement, Battery: step 5, image 1 of 3 Motorola Moto G3 Battery Replacement, Battery: step 5, image 2 of 3 Motorola Moto G3 Battery Replacement, Battery: step 5, image 3 of 3
    • With a T4 screwdriver, remove the 10 "yellow" 2mm screws and 4 "black" 2mm screws.
  6. Motorola Moto G3 Battery Replacement: step 6, image 1 of 2 Motorola Moto G3 Battery Replacement: step 6, image 2 of 2
    • Use the metal spudger and lift the back cover on the bottom side of the phone (this is attached to the motherboard).
  7. Motorola Moto G3 Battery Replacement: step 7, image 1 of 1
    Buy
    • Remove the red and black battery cable from its port using tweezers.
  8. Motorola Moto G3 Battery Replacement: step 8, image 1 of 2 Motorola Moto G3 Battery Replacement: step 8, image 2 of 2
    • Use the same tweezers to remove the red battery from where it is placed.
4 other people completed this guide.
Irkan Notta
1,034 Reputation
7 Guides authored
Baylor, Team S5-G3, Williams Spring 2018 Member of Baylor, Team S5-G3, Williams Spring 2018
BU-WILLIAMS-S18S5G3
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 976
