Motorola Moto G3 Motherboard Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Motorola Moto G3 Motherboard  Replacement, Prerequisite Guide: step 1, image 1 of 2 Motorola Moto G3 Motherboard  Replacement, Prerequisite Guide: step 1, image 2 of 2
    • Use the plastic opening tool to open the back cover as shown in the photo.
  2. Motorola Moto G3 Motherboard  Replacement: step 2, image 1 of 1
    • Heat an iOpener in the microwave for 30 seconds.
    • Place the heated iOpener on all four edges of the screen for approximately 2 minutes.
  3. Motorola Moto G3 Motherboard  Replacement: step 3, image 1 of 1
    • Apply the plastic opening tool on the edge of the screen near the front camera.
    • After creating enough space, allow the opening tool to be inserted on the side of the phone.
    • Create another space on the other side of the screen.
    • Leave the opening tool inserted.
    • Carefully apply the larger plastic opening tool by sliding it through the longer edge of the screen.
  4. Motorola Moto G3 Motherboard  Replacement: step 4, image 1 of 3 Motorola Moto G3 Motherboard  Replacement: step 4, image 2 of 3 Motorola Moto G3 Motherboard  Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • A strip will be attached to the motherboard as shown.
    • Using tweezers, carefully detach the strip from the motherboard.
  5. Motorola Moto G3 Motherboard  Replacement, Motherboard: step 5, image 1 of 3 Motorola Moto G3 Motherboard  Replacement, Motherboard: step 5, image 2 of 3 Motorola Moto G3 Motherboard  Replacement, Motherboard: step 5, image 3 of 3
    • With a T4 screwdriver, remove the10 "yellow" 2mm screws and 4 "black" 2mm screws.
  6. Motorola Moto G3 Motherboard  Replacement: step 6, image 1 of 2 Motorola Moto G3 Motherboard  Replacement: step 6, image 2 of 2
    • Use the metal spudger and lift the back cover on the bottom side of the phone (this is attached to the motherboard).
    • Remove the motherboard from the device.
3 other people completed this guide.
Irkan Notta
1,034 Reputation
7 Guides authored
Baylor, Team S5-G3, Williams Spring 2018 Member of Baylor, Team S5-G3, Williams Spring 2018
BU-WILLIAMS-S18S5G3
3 Members
9 Guides authored
One Comment
i broke my battery connectig port where we plug in the battery. What should i do?
PLZ answer
All you need to Know (SAMMY) - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 483
