Motorola Moto G3 Rear Camera Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Motorola Moto G3 Rear Camera  Replacement, Prerequisite Guide: step 1, image 1 of 2 Motorola Moto G3 Rear Camera  Replacement, Prerequisite Guide: step 1, image 2 of 2
    • Use the plastic opening tool to open the back cover as shown in the photo.
  2. Motorola Moto G3 Rear Camera  Replacement: step 2, image 1 of 1
    • Heat an iOpener in the microwave for 30 seconds.
    • Place the heated iOpener on all four edges of the screen for approximately 2 minutes.
  3. Motorola Moto G3 Rear Camera  Replacement: step 3, image 1 of 1
    • Apply the plastic opening tool on the edge of the screen near the front camera.
    • After creating enough space, allow the opening tool to be inserted on the side of the phone.
    • Create another space on the other side of the screen.
    • Leave the opening tool inserted.
    • Carefully apply the larger plastic opening tool by sliding it through the longer edge of the screen.
  4. Motorola Moto G3 Rear Camera  Replacement: step 4, image 1 of 3 Motorola Moto G3 Rear Camera  Replacement: step 4, image 2 of 3 Motorola Moto G3 Rear Camera  Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • A strip will be attached to the motherboard as shown.
    • Using tweezers, carefully detach the strip from the motherboard.
  5. Motorola Moto G3 Rear Camera  Replacement, Rear Camera: step 5, image 1 of 3 Motorola Moto G3 Rear Camera  Replacement, Rear Camera: step 5, image 2 of 3 Motorola Moto G3 Rear Camera  Replacement, Rear Camera: step 5, image 3 of 3
    • With a T4 screwdriver, remove the10 "yellow" 2mm screws and 4 "black" 2mm screws.
  6. Motorola Moto G3 Rear Camera  Replacement: step 6, image 1 of 3 Motorola Moto G3 Rear Camera  Replacement: step 6, image 2 of 3 Motorola Moto G3 Rear Camera  Replacement: step 6, image 3 of 3
    • Use the metal spudger and lift the back cover on the bottom side of the phone (this is attached to the motherboard).
  7. Motorola Moto G3 Rear Camera  Replacement: step 7, image 1 of 1
    • Flip the motherboard over.
  8. Motorola Moto G3 Rear Camera  Replacement: step 8, image 1 of 1
    • Using a T4 Torx screwdriver, remove the three 2mm screws.
  9. Motorola Moto G3 Rear Camera  Replacement: step 9, image 1 of 2 Motorola Moto G3 Rear Camera  Replacement: step 9, image 2 of 2
    Buy
    • Using the tweezers remove the black rear camera cover.
  10. Motorola Moto G3 Rear Camera  Replacement: step 10, image 1 of 2 Motorola Moto G3 Rear Camera  Replacement: step 10, image 2 of 2
    • Using the small opening tool, carefully flip the camera flex connector in a upright position. You should hear a click allowing you to know the camera flex connector has been released.
  11. Motorola Moto G3 Rear Camera  Replacement: step 11, image 1 of 1
    • Take the tweezers and remove the camera from the motherboard.
Irkan Notta
1,034 Reputation
7 Guides authored
Baylor, Team S5-G3, Williams Spring 2018 Member of Baylor, Team S5-G3, Williams Spring 2018
BU-WILLIAMS-S18S5G3
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 222
