Motorola Moto G32 Charge Port Replacement
Ryannm
Ryannm and 2 other contributors
Last updated on March 18, 2024
40 minutes
Moderate
Community-Contributed Guide
Introduction
Go to step 1
In this short guide I will walk through the process of replacing the charge port on a Motorola G32 ( Model number: XT2235-2 )
Motorola charge port part number: 5P68C21161
this specific repair was a liquid damaged device from a customer.
Parts
Tools
Show more…
  1. Motorola Moto G32 Charge Port Replacement, Rear panel removal: step 1, image 1 of 2 Motorola Moto G32 Charge Port Replacement, Rear panel removal: step 1, image 2 of 2
    • Start by heating the device for about 5-10 minutes at approximately 50-70 degrees celsius
    • Use a suction cup on the rear panel of the device to create an initial gap to slide a guitar pick in and separate the rear panel from the device
    • Remove the sim tray from the device
  2. Motorola Moto G32 Charge Port Replacement, Remove midframe screws: step 2, image 1 of 1
    • Remove all visable screws on the mid frame of the device and store safely using a PH000 screwdriver
  3. Motorola Moto G32 Charge Port Replacement, Removing midframe: step 3, image 1 of 2 Motorola Moto G32 Charge Port Replacement, Removing midframe: step 3, image 2 of 2
    • Wedge a pick between the coloured frame and the black plastic screen edge and slide it down each edge of the device to unclip the midframe
    • Once the entire midframe has been removed open to the left side carefully as there is a cable plugged into the main board that is short and easy to damage.
  4. Motorola Moto G32 Charge Port Replacement, Disconnecting necessary components: step 4, image 1 of 3 Motorola Moto G32 Charge Port Replacement, Disconnecting necessary components: step 4, image 2 of 3 Motorola Moto G32 Charge Port Replacement, Disconnecting necessary components: step 4, image 3 of 3
    • Disconnect the battery connector to isolate power to the device to prevent damage during repair
    • Disconnect the ribbon cable for the fingerprint scanner from the motherboard, at this point you can place the midframe aside.
    • Disconnect the antenna connection and the charge port connection
  5. Motorola Moto G32 Charge Port Replacement, Charge port: step 5, image 1 of 1
    • Remove the loudspeaker and then chargeport board and swap with the new component. Ensuring the water and dust resistant gaskets over the aux port and Type C port are transferred to the new port
  6. Motorola Moto G32 Charge Port Replacement, Finishing up: step 6, image 1 of 1
    • Repeat all previous steps in reverse ensuring the battery is plugged in last to prevent damage
    • Re seal the back panel onto the device with a new adhesive gasket, In my case i have cut TESA as close to the original template as possible which for this device will be more than sufficient
Hopefully by this point you should have a working device.
5 other people completed this guide.
Ryannm
326 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 93
All Time: 1,205
