Motorola Moto G4 Play Battery Replacement
  1. Motorola Moto G4 Play Battery Replacement, Battery: step 1, image 1 of 3 Motorola Moto G4 Play Battery Replacement, Battery: step 1, image 2 of 3 Motorola Moto G4 Play Battery Replacement, Battery: step 1, image 3 of 3
    • Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
  2. Motorola Moto G4 Play Battery Replacement: step 2, image 1 of 3 Motorola Moto G4 Play Battery Replacement: step 2, image 2 of 3 Motorola Moto G4 Play Battery Replacement: step 2, image 3 of 3
    • Lift the case by the nearest corner to the divot and remove it from the phone.
  3. Motorola Moto G4 Play Battery Replacement: step 3, image 1 of 3 Motorola Moto G4 Play Battery Replacement: step 3, image 2 of 3 Motorola Moto G4 Play Battery Replacement: step 3, image 3 of 3
    • Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
    • Remove battery from your phone.
6 other people completed this guide.
Paola Rossi
502 Reputation
3 Guides authored
USF Tampa, Team S17-G4, Boczar Spring 2018 Member of USF Tampa, Team S17-G4, Boczar Spring 2018
USFT-BOCZAR-S18S17G4
4 Members
11 Guides authored
One Comment
Precio de la bateria
Elimar Johana Lugo Gil - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 4,731
