Motorola Moto G4 Plus Battery Replacement
  1. Motorola Moto G4 Plus Battery Replacement, SIM Card: step 1, image 1 of 2 Motorola Moto G4 Plus Battery Replacement, SIM Card: step 1, image 2 of 2
    • Insert a fingernail or a spudger into the notch on bottom edge of the phone near the charging port.
    • Pry the back cover away from the body of the phone.
  2. Motorola Moto G4 Plus Battery Replacement: step 2, image 1 of 3 Motorola Moto G4 Plus Battery Replacement: step 2, image 2 of 3 Motorola Moto G4 Plus Battery Replacement: step 2, image 3 of 3
    • Continue to gently lift the back cover until all plastic clips have been released.
    • Remove the back cover.
    • To reinstall the back cover, align the cover over the body and gently press all around the edges until you feel the clips snap into place.
  3. Motorola Moto G4 Plus Battery Replacement: step 3, image 1 of 2 Motorola Moto G4 Plus Battery Replacement: step 3, image 2 of 2
    • Slide out and remove the SIM card.
  4. Motorola Moto G4 Plus Battery Replacement, Battery: step 4, image 1 of 1
    • Remove the nineteen 3.1 mm T3 screws securing the midframe.
  5. Motorola Moto G4 Plus Battery Replacement: step 5, image 1 of 2 Motorola Moto G4 Plus Battery Replacement: step 5, image 2 of 2
    • Use the point of a spudger to pry up the rubber cover over the camera flash connector.
    • Remove the rubber cover.
  6. Motorola Moto G4 Plus Battery Replacement: step 6, image 1 of 2 Motorola Moto G4 Plus Battery Replacement: step 6, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the camera flash connector.
  7. Motorola Moto G4 Plus Battery Replacement: step 7, image 1 of 3 Motorola Moto G4 Plus Battery Replacement: step 7, image 2 of 3 Motorola Moto G4 Plus Battery Replacement: step 7, image 3 of 3
    • Loosen the midframe along the edges and lift it away from the body.
    • Remove the midframe.
  8. Motorola Moto G4 Plus Battery Replacement: step 8, image 1 of 2 Motorola Moto G4 Plus Battery Replacement: step 8, image 2 of 2
    • Be very careful not to puncture the battery with any sharp tools. A damaged lithium-ion battery can catch fire and/or explode.
    • Peel up and remove the tape securing the battery wires.
    • Peel up and remove the black tape that bridges the battery and the phone.
    • While neither tape pieces are necessary for the operation of the phone, save them if they are in good condition for the reinstallation process.
  9. Motorola Moto G4 Plus Battery Replacement: step 9, image 1 of 2 Motorola Moto G4 Plus Battery Replacement: step 9, image 2 of 2
    • Slip the point of a spudger underneath the red and black battery wires and gently pry straight up.
    • Do not pull the plug out, or you will tear the board socket out. Be careful where you pry. Do not pry against the board socket.
    • During reassembly, align the connector in its socket, then press straight down to reconnect it.
  10. Motorola Moto G4 Plus Battery Replacement: step 10, image 1 of 2 Motorola Moto G4 Plus Battery Replacement: step 10, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers or your fingers to de-route the battery wires from the plastic brackets.
  11. Motorola Moto G4 Plus Battery Replacement: step 11, image 1 of 3 Motorola Moto G4 Plus Battery Replacement: step 11, image 2 of 3 Motorola Moto G4 Plus Battery Replacement: step 11, image 3 of 3
    • Peel the black pull tab from battery and pull slowly but firmly to separate the battery from the frame.
    • A few drops of high concentration (90% or higher) isopropyl alcohol along each side may help soften the adhesive.
    • If the pull tab breaks, use a spudger to gently pry around the edges of the battery until it comes loose.
    • Don't deform or puncture the battery—it can catch fire and/or explode if damaged.
    • Never reinstall a damaged or deformed battery. Replace the battery.
  12. Motorola Moto G4 Plus Battery Replacement: step 12, image 1 of 1
    Tesa 61395 Tape
    $5.99
    Buy
    • Remove the battery.
    • To install a battery, orient the new battery such that the wires exit near the bottom of the phone, and the battery connector is on the motherboard side.
    • Clean off any adhesive residue which may prevent the battery from sitting flush against the frame. Use a few strips of adhesive included in the battery kit or some double-sided tape to secure the battery to the frame.
After completing this guide, calibrate your newly-installed battery.
Repair didn’t go as planned? Check out our Motorola Moto G4 Plus Answers community for troubleshooting help.
50 other people completed this guide.
Arthur Shi
283,063 Reputation
587 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,537 Guides authored
10 Comments
in step 9, when i took the connector away the hole plug came out :( need micro soldering to paste the conector to the board
Jorge Martinez - Reply
I’m really sorry to hear that! I’ll add some extra warning on that step.
Arthur Shi -
One of the last screws stripped and I wasn't applying a lot of force. Being a jeweler, I tried every trick I knew of but that sucker would not budge. Since it was a corner screw, I rotated the entire cover (while pulling up on it to miss the components directly beneath) to expose all of the battery area. Hope I explained that part well enough. The battery was also tough to remove. I think they used way too much glue the first time around. Anyway, I was thrilled it powered right up with the new battery and I saved over $50 bucks doing it myself (and with the help of ifixit.com). Thanks!
Anna White - Reply
Thank you for the guide! My wife and I did it together and the steps were very clear.
Abhay Ramakrishnan - Reply
Mega mega mega, kinderleicht, Spitzenbeschreibung…
Alexander Albrecht - Reply
Past 24 Hours: 0
Past 7 Days: 31
Past 30 Days: 151
All Time: 46,124
