Introduction
This guide will walk you through how to replace a damaged motherboard in a Motorola Moto G5 Plus.
Use a SIM eject bit, SIM eject tool, or paper clip to remove the SIM card from your phone.
Prepare an iOpener and heat the front of the phone along its left edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the display.
Apply a suction cup to the display, near the middle of the left edge.
Pull the suction cup with firm, constant pressure to create a slight gap between the display panel and the rear case.
If the display doesn't separate even with significant force, apply more heat to further soften the adhesive and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Tool used on this step:Tesa 61395 Tape$5.99
Once the battery is loose, remove it from the phone.
Remove any remaining adhesive from the phone, and clean the entire area under the battery with isopropyl alcohol.
Apply a few new strips of pre-cut adhesive or Tesa tape.
Press the new battery firmly into place for 5-10 seconds.
Gently pry the 12-megapixel G5 Plus rear-facing camera up using the plastic opening tool, exposing the ZIF connector.
10 other people completed this guide.
11 Comments
The power button broke off the motherboard on my G5 plus, so I would like to solder it back into place. I think I need a large, high magnification lens to see the details during the process. Any suggestions?
My phone get into the water so its now dead. i would like to chnage the motherboard. SO could you please share the website from there i can get the whole motherboard in lowest price. I had contact to service centre but they are asking a 80% of the phone cast. Please give me a detail on below email id- ankitkulhade123@gmail.com
Is your problem solved now? I’m also facing same problem, they are asking 80% of mobile cost.. what to do now?
I am facing the same issue with my Moto G5 Plus. The mobile was drawn into water and instantly I pulled it back. I tried drying the phone with raw rice and sunlight. After 3-4 days the phone started working. I used it a whole day but as the better was discharged, the phone was switched off and unlimately dead. The moto service center declared that the motherboard is dead now. Please suggest if it can be fixed?
Sir my moto g5s plus mother board damage due to water and it's only 6 month old so what I do.
Service centre says that repairing not posible because it is not in warranty.
How I get new mother at affordable price.
