Motorola Moto G7 Plus Battery Removal
  1. Motorola Moto G7 Plus Battery Removal, Remove the Screen: step 1, image 1 of 2 Motorola Moto G7 Plus Battery Removal, Remove the Screen: step 1, image 2 of 2
    • Insert an opening tool pick under the screen, starting at the top of the phone.
    • Slide the pick around the entire perimeter of the display to break the adhesive.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to damage this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
    • While not necessary, applying a gentle heat to the edges of the display with a heat gun or iOpener will weaken the adhesive.
  2. Motorola Moto G7 Plus Battery Removal, Remove the Display Cable Cover: step 2, image 1 of 2 Motorola Moto G7 Plus Battery Removal, Remove the Display Cable Cover: step 2, image 2 of 2
    • Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
    • Gently remove the metal piece that covers the base of the display cable.
  3. Motorola Moto G7 Plus Battery Removal: step 3, image 1 of 2 Motorola Moto G7 Plus Battery Removal: step 3, image 2 of 2
    • Use the pointed end of the spudger to lift the metal casing where circled.
  4. Motorola Moto G7 Plus Battery Removal, Separate the Display From the Phone: step 4, image 1 of 2 Motorola Moto G7 Plus Battery Removal, Separate the Display From the Phone: step 4, image 2 of 2
    • Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
  5. Motorola Moto G7 Plus Battery Removal, Cut the Black Tape and the Connector Before Removal: step 5, image 1 of 2 Motorola Moto G7 Plus Battery Removal, Cut the Black Tape and the Connector Before Removal: step 5, image 2 of 2
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Use the blade end of a Halberd Spudger to cut through the two strips of black tape attached to the battery.
    • Use the flat end of a spudger to disconnect the battery from the phone.
  6. Motorola Moto G7 Plus Battery Removal, Remove the Battery: step 6, image 1 of 2 Motorola Moto G7 Plus Battery Removal, Remove the Battery: step 6, image 2 of 2
    • Take the battery out with the flat end of the spudger.
    • Handling batteries can be dangerous. Be very careful not to puncture the battery, as there are dangerous chemicals inside. Physical damage to the battery can cause it to burst into flame and release toxic smoke.
15 other people completed this guide.
Jack Browers
385 Reputation
1 Guide authored
Cal Poly, Team S22-G5, Regan Winter 2020 Member of Cal Poly, Team S22-G5, Regan Winter 2020
CPSU-REGAN-W20S22G5
5 Members
19 Guides authored
4 Comments
bricked, the display is not recognized anymore after re-attaching
Mrs Glue - Reply
as an additional information: my phone is bricked, because i severed a connection of the display, which is located at the bottom of the phone - you should only enter the pick up to a depth of ~ 2-3mm at the bottom!
Mrs Glue - Reply
Went as smoothly as possible, thanks very much. Only the glue under the battery was a serious pain in the butt.
Kevin Silbstedt - Reply
Followed the steps, and now my phone is working again. Thanks for the guide.
Gary Campbell - Reply
Past 24 Hours: 10
Past 7 Days: 56
Past 30 Days: 217
All Time: 23,949
