Motorola Moto G7 Rear Facing Camera Replacement
  1. Motorola Moto G7 Rear Facing Camera  Replacement, Screen: step 1, image 1 of 3 Motorola Moto G7 Rear Facing Camera  Replacement, Screen: step 1, image 2 of 3 Motorola Moto G7 Rear Facing Camera  Replacement, Screen: step 1, image 3 of 3
    • Use the iFixit opening tools to gently wedge the front screen from the rest of the device.
    • Try to focus on the corners to make it easier to insert and use the iFixit opening picks.
    • It is also recommended to use the iOpener or a heat gun to weaken the adhesive that holds the edges of the screen down.
    • The screen is glass, so when using force to lift the screen, be cautious of cracked glass and stray shards of glass coming off.
    • You have to be extra careful to dig deep enough, so you lift the entire screen unit!
  2. Motorola Moto G7 Rear Facing Camera  Replacement: step 2, image 1 of 1
    • Excessive glass and adhesive around the edges should be removed with the spudger.
    • The glass is black and may blend in with edges of the device. Be cautious using bare hands when moving the device.
  3. Motorola Moto G7 Rear Facing Camera  Replacement: step 3, image 1 of 2 Motorola Moto G7 Rear Facing Camera  Replacement: step 3, image 2 of 2
    • Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery.
  4. Motorola Moto G7 Rear Facing Camera  Replacement: step 4, image 1 of 3 Motorola Moto G7 Rear Facing Camera  Replacement: step 4, image 2 of 3 Motorola Moto G7 Rear Facing Camera  Replacement: step 4, image 3 of 3
    • Use a spudger to gently take off the metal piece that was held down by the screws.
    • A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band.
  5. Motorola Moto G7 Rear Facing Camera  Replacement, Camera: step 5, image 1 of 3 Motorola Moto G7 Rear Facing Camera  Replacement, Camera: step 5, image 2 of 3 Motorola Moto G7 Rear Facing Camera  Replacement, Camera: step 5, image 3 of 3
    • Remove by the six 2.7mm T3 Torx screws from the metal panel above the battery.
    • Wedge a spudger between the SD card tray and the metal plate, and use a medium amount of force to pry up the plate.
  6. Motorola Moto G7 Rear Facing Camera  Replacement: step 6, image 1 of 1
    • Use a spudger beneath the right side of the connector to detach it.
  7. Motorola Moto G7 Rear Facing Camera  Replacement: step 7, image 1 of 3 Motorola Moto G7 Rear Facing Camera  Replacement: step 7, image 2 of 3 Motorola Moto G7 Rear Facing Camera  Replacement: step 7, image 3 of 3
    • Detach the two small black and white connectors on either side of the camera using a spudger.
    • Remove the camera from the smartphone.
Peter Nelson
742 Reputation
3 Guides authored
Cal Poly, Team S19-G6, White Winter 2020 Member of Cal Poly, Team S19-G6, White Winter 2020
CPSU-WHITE-W20S19G6
4 Members
20 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 29
All Time: 1,150
