Motorola Moto Z2 Play Battery Replacement
mitch miller
mitch miller and 11 other contributors
Last updated on July 29, 2024
15 minutes
Moderate
Featured Student Guide
Introduction
Go to step 1
Use this guide to remove and replace a dead or low battery in a Motorola Moto Z2 Play. If your battery is swollen, take appropriate precautions.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Warning: Because of the strong adhesive securing the display, minimal clearance for inserting your tools, and high heat required, there's a good chance of accidentally damaging the display when removing it. If you intend to re-use the display, take serious care when heating and inserting tools to separate the display from the rest of the device.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
  1. Motorola Moto Z2 Play Battery Replacement, Screen Removal: step 1, image 1 of 1
    • Power off your phone before you complete any replacement steps.
  2. Motorola Moto Z2 Play Battery Replacement: step 2, image 1 of 1
    • Heat the edges of your Motorola Moto Z2 Play screen for two to three minutes with a heat gun. You adjust the heat gun to 85 degrees centigrade, and be careful not to hold the heat gun on one position for too long; to avoid damaging, or "hotspotting" the LCD. The screen should be very warm, but not painful, to the touch. Reheat as necessary.
    • If screen is cracked put strong adhesive tape across the screen in order to avoid breaking the screen further and receiving cuts.
    • If you don’t have access to a heat gun, a hair dryer can be used.
  3. Motorola Moto Z2 Play Battery Replacement: step 3, image 1 of 1
    • Place suction cup in the middle of the screen and press down.
  4. Motorola Moto Z2 Play Battery Replacement: step 4, image 1 of 3 Motorola Moto Z2 Play Battery Replacement: step 4, image 2 of 3 Motorola Moto Z2 Play Battery Replacement: step 4, image 3 of 3
    • Pry the screen by wedging the plastic opening tool under the screen at the charging port.
    • Work your way around the screen with the plastic opening tool.
    • When you pry near the top-right and bottom-right corners, be careful not to pry too far, or you risk damaging the display cable.
    • Complete these steps carefully because the screen is delicate and can easily crack. If the screen begins to resist prying, reheat the adhesive with your heat gun.
  5. Motorola Moto Z2 Play Battery Replacement: step 5, image 1 of 3 Motorola Moto Z2 Play Battery Replacement: step 5, image 2 of 3 Motorola Moto Z2 Play Battery Replacement: step 5, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    • Use a suction cup to lift up screen from left to right.
    • If you don’t have a suction cup, wedge a spudger or a small plastic card under the screen and lift slowly.
    • Failure to lift screen from left to right can cause damage to interior wires of your phone.
  6. Motorola Moto Z2 Play Battery Replacement: step 6, image 1 of 3 Motorola Moto Z2 Play Battery Replacement: step 6, image 2 of 3 Motorola Moto Z2 Play Battery Replacement: step 6, image 3 of 3
    • Identify ribbon connector at the top right of the phone.
    • Pry the black locking bar up gently with a plastic opening tool.
    • Remove the ribbon wires by pulling them out of the connector with a tweezer.
    • The locking bar is the small black bar located on the digitizer’s ZIF connector.
    • Be sure to push the locking bar back down using a spudger after you put the ribbon wire back in since the lock does not lock automatically.
  7. Motorola Moto Z2 Play Battery Replacement: step 7, image 1 of 3 Motorola Moto Z2 Play Battery Replacement: step 7, image 2 of 3 Motorola Moto Z2 Play Battery Replacement: step 7, image 3 of 3
    • Identify the ribbon cable, located at the bottom right of the phone.
    • If present, remove kapton (orange) tape covering the cable connector.
    • Flip up the small locking flap on the ZIF connector and use tweezers to slide the cable straight out of its socket.
    • Excessive force is not needed.
  8. Motorola Moto Z2 Play Battery Replacement: step 8, image 1 of 1
    • Lift the screen from the phone to completely detach.
    • If screen doesn't detach, go back to step 7 and 8 to make sure the bar is unlocked and ribbon connector is fully detached.
    • During reassembly, you may need to apply or replace the display adhesive on your display assembly. Use our display adhesive application guide to apply the adhesive and reseal your device.
  9. Motorola Moto Z2 Play Battery Replacement, Battery: step 9, image 1 of 2 Motorola Moto Z2 Play Battery Replacement, Battery: step 9, image 2 of 2
    • Remove the orange tape, located at the bottom right of the phone, using tweezers.
    • Do not discard tape.
  10. Motorola Moto Z2 Play Battery Replacement: step 10, image 1 of 2 Motorola Moto Z2 Play Battery Replacement: step 10, image 2 of 2
    • Detach the red and black battery wire by lifting up with tweezers.
  11. Motorola Moto Z2 Play Battery Replacement: step 11, image 1 of 2 Motorola Moto Z2 Play Battery Replacement: step 11, image 2 of 2
    • Peel back the black tape that is located on the battery.
    • Make sure you pull back gently so you can reuse the tape with reassembly.
  12. Motorola Moto Z2 Play Battery Replacement: step 12, image 1 of 3 Motorola Moto Z2 Play Battery Replacement: step 12, image 2 of 3 Motorola Moto Z2 Play Battery Replacement: step 12, image 3 of 3
    • Lift the black tape and slide a card under the battery.
    • Align the card parallel and under the battery.
    • Wedge the card further under the battery.
    • Lift the card up to assist in removing the battery from the adhesive.
  13. Motorola Moto Z2 Play Battery Replacement: step 13, image 1 of 1
    • Lift to remove the battery from the device completely.
After completing this guide, calibrate your newly-installed battery.
38 other people completed this guide.
mitch miller
2,070 Reputation
8 Guides authored
Cal Poly, Team S19-G5, Livingston Winter 2018 Member of Cal Poly, Team S19-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G5
4 Members
30 Guides authored
11 Comments
Awesome guide! where can someone get a replacement battery in Canada?
xbddd777 - Reply
Great instructions, clear and concise.
thank you
David Wyatt - Reply
so now that I've heated the adhesive to get the screen off do I need to apply new adhesive? or simply reheat it?
eli Factotum - Reply
Hi Eli,
The most ideal option would be to replace the adhesive. This ensures the best chance for your phone to stay sealed. You can re-use the existing adhesive and it may work well enough for awhile.
Arthur Shi -
What type/brand adhesive do you recommend for this screen instead of trying to reuse the old adhesive. Typical 3M strips?
Jason - Reply
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 115
All Time: 37,997
