Motorola Q Global Camera Replacement
  1. Motorola Q Global Camera Replacement, Battery: step 1, image 1 of 1
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Camera Replacement: step 2, image 1 of 2 Motorola Q Global Camera Replacement: step 2, image 2 of 2
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Camera Replacement, Camera: step 3, image 1 of 1
    • Press inward on the upper casing.
  4. Motorola Q Global Camera Replacement: step 4, image 1 of 1
    • Slide the upper case to the right and lift up.
    • Lift the camera sticker so that it doesn't get damaged.
  5. Motorola Q Global Camera Replacement: step 5, image 1 of 2 Motorola Q Global Camera Replacement: step 5, image 2 of 2
    • Remove the six labeled screws with a T5 Torx Screwdriver.
  6. Motorola Q Global Camera Replacement: step 6, image 1 of 1
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Camera Replacement: step 7, image 1 of 2 Motorola Q Global Camera Replacement: step 7, image 2 of 2
    • Remove both screws on the mounted surface with a T5 screwdriver.
  8. Motorola Q Global Camera Replacement: step 8, image 1 of 2 Motorola Q Global Camera Replacement: step 8, image 2 of 2
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
  9. Motorola Q Global Camera Replacement: step 9, image 1 of 1
    • Use the plastic opening tool to lift the camera from the phone.
  10. Motorola Q Global Camera Replacement: step 10, image 1 of 1
    • The new camera can now be attached to the motherboard.
Jorge Vanegas Moran
8 Reputation
1 Guide authored
Cal Poly, Team 6-31, Regan Fall 2012 Member of Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
5 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 765
