Motorola Q Global Speakers Replacement
  1. Motorola Q Global Speakers Replacement, Battery: step 1, image 1 of 1
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Speakers Replacement: step 2, image 1 of 2 Motorola Q Global Speakers Replacement: step 2, image 2 of 2
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Speakers Replacement, Speakers: step 3, image 1 of 1
    • Press inwardly on the upper casing until it pops out of the phone.
  4. Motorola Q Global Speakers Replacement: step 4, image 1 of 1
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  5. Motorola Q Global Speakers Replacement: step 5, image 1 of 2 Motorola Q Global Speakers Replacement: step 5, image 2 of 2
    • Remove the six labeled screws with a T5 torx screw driver.
  6. Motorola Q Global Speakers Replacement: step 6, image 1 of 1
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Speakers Replacement: step 7, image 1 of 1
    • Remove the speakers by using the plastic remover tool.
  8. Motorola Q Global Speakers Replacement: step 8, image 1 of 1
    • Insert the new speakers by gently pressing them down into place.
Carlos De La Parra
14 Reputation
1 Guide authored
Cal Poly, Team 6-31, Regan Fall 2012 Member of Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
5 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 646
