Introduction
The external speaker is located under the motherboard of the phone, making it necessary to take out the motherboard to access the speaker. This guide involves the removal of various screws and parts so make sure you are in a clean and organized environment to avoid the loss of any components.
Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
Remove the plastic yellow tape on the battery connector using the spudger.
Pry up on the orange connection to release it from the motherboard.
