Motorola RAZR Maxx HD Front-Facing Camera Replacement
  1. Motorola RAZR Maxx HD Front-Facing Camera Replacement, Screen Removal: step 1, image 1 of 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement, Screen Removal: step 1, image 2 of 2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Front-Facing Camera Replacement: step 2, image 1 of 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: step 2, image 2 of 2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Front-Facing Camera Replacement: step 3, image 1 of 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: step 3, image 2 of 2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Front-Facing Camera Replacement: step 4, image 1 of 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: step 4, image 2 of 2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Front-Facing Camera Replacement, Front-Facing Camera: step 5, image 1 of 1
    • On the back of the LCD display, release the yellow front-facing camera ribbon cable by gently lifting upward on the black retaining clip with the spudger.
  6. Motorola RAZR Maxx HD Front-Facing Camera Replacement: step 6, image 1 of 3 Motorola RAZR Maxx HD Front-Facing Camera Replacement: step 6, image 2 of 3 Motorola RAZR Maxx HD Front-Facing Camera Replacement: step 6, image 3 of 3
    • With a Torx T3 screwdriver, unscrew the two 2.0 mm screws on front-facing camera mounting bracket. Then lift to remove it.
  7. Motorola RAZR Maxx HD Front-Facing Camera Replacement: step 7, image 1 of 2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove the front-facing camera by lifting it from the LCD display frame.
Jacob Syage
284 Reputation
2 Guides authored
Cal Poly, Team 8-40, Amido Winter 2015 Member of Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 310
