Motorola SLVR L9 Antenna Cover Replacement
  1. Motorola SLVR L9 Antenna Cover Replacement, Battery: step 1, image 1 of 2 Motorola SLVR L9 Antenna Cover Replacement, Battery: step 1, image 2 of 2
    • Turn the phone over so that the back of the phone is facing up.
  2. Motorola SLVR L9 Antenna Cover Replacement: step 2, image 1 of 3 Motorola SLVR L9 Antenna Cover Replacement: step 2, image 2 of 3 Motorola SLVR L9 Antenna Cover Replacement: step 2, image 3 of 3
    • Press down on the silver battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
  3. Motorola SLVR L9 Antenna Cover Replacement: step 3, image 1 of 3 Motorola SLVR L9 Antenna Cover Replacement: step 3, image 2 of 3 Motorola SLVR L9 Antenna Cover Replacement: step 3, image 3 of 3
    • To remove the battery, pull the battery up from the bottom center.
  4. Motorola SLVR L9 Antenna Cover Replacement, Antenna Cover: step 4, image 1 of 3 Motorola SLVR L9 Antenna Cover Replacement, Antenna Cover: step 4, image 2 of 3 Motorola SLVR L9 Antenna Cover Replacement, Antenna Cover: step 4, image 3 of 3
    • Use the plastic opening tool to loosen the cover latch.
    • Once the cover latch has been loosened, gently pull the cover latch off of the device.
Eric Lopez
201 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 152
