Motorola SURFboard SB5101 Metal Receiver Replacement
  1. Motorola SURFboard SB5101 Metal Receiver Replacement, Removing the Screw on the Back of the Device: step 1, image 1 of 3 Motorola SURFboard SB5101 Metal Receiver Replacement, Removing the Screw on the Back of the Device: step 1, image 2 of 3 Motorola SURFboard SB5101 Metal Receiver Replacement, Removing the Screw on the Back of the Device: step 1, image 3 of 3
    • Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
    • Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
    • Remove the screw and set aside.
  2. Motorola SURFboard SB5101 Metal Receiver Replacement, Unlocking Router: step 2, image 1 of 3 Motorola SURFboard SB5101 Metal Receiver Replacement, Unlocking Router: step 2, image 2 of 3 Motorola SURFboard SB5101 Metal Receiver Replacement, Unlocking Router: step 2, image 3 of 3
    • Rotate your device 90 degrees to the right so that the bottom of the device is facing you.
    • Locate the two horizontal slots on the bottom of the device.
    • You may need to remove the sticker on the bottom of the device to access these slots.
    • Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
    • Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
    • Repeat with the other slot to completely unlock the device.
  3. Motorola SURFboard SB5101 Metal Receiver Replacement, Removing the Cover: step 3, image 1 of 3 Motorola SURFboard SB5101 Metal Receiver Replacement, Removing the Cover: step 3, image 2 of 3 Motorola SURFboard SB5101 Metal Receiver Replacement, Removing the Cover: step 3, image 3 of 3
    • Grab the top and the bottom of the device and gently pull the device open.
    • Continue pulling until you have completely removed the top cover of the device.
    • When reassembling your device, make sure the standby key is properly in place. See the Standby Key Guide for more information.
    • Also ensure that when you close the two sides of the cover the LED indicator lights are inside the information panel.
  4. Motorola SURFboard SB5101 Metal Receiver Replacement, Grabbing the Motherboard: step 4, image 1 of 2 Motorola SURFboard SB5101 Metal Receiver Replacement, Grabbing the Motherboard: step 4, image 2 of 2
    • After opening the router, grab the upper left corner of the sliver face plate and gently pull the motherboard out of the slot from within the case.
  5. Motorola SURFboard SB5101 Metal Receiver Replacement, Removing the Motherboard: step 5, image 1 of 3 Motorola SURFboard SB5101 Metal Receiver Replacement, Removing the Motherboard: step 5, image 2 of 3 Motorola SURFboard SB5101 Metal Receiver Replacement, Removing the Motherboard: step 5, image 3 of 3
    • Slowly lift the motherboard out of the case.
  6. Motorola SURFboard SB5101 Metal Receiver Replacement, Positioning the Prying Tool: step 6, image 1 of 2 Motorola SURFboard SB5101 Metal Receiver Replacement, Positioning the Prying Tool: step 6, image 2 of 2
    • Holding the motherboard by the metal face plate, position the flat end of a prying tool under one of the prongs of the metal square plate.
  7. Motorola SURFboard SB5101 Metal Receiver Replacement, Pivoting the Prying Tool: step 7, image 1 of 2 Motorola SURFboard SB5101 Metal Receiver Replacement, Pivoting the Prying Tool: step 7, image 2 of 2
    • Slowly and evenly tilt the prying tool so that the metal plate begins to lift up.
  8. Motorola SURFboard SB5101 Metal Receiver Replacement, Lifting Another Corner: step 8, image 1 of 2 Motorola SURFboard SB5101 Metal Receiver Replacement, Lifting Another Corner: step 8, image 2 of 2
    • Re-position the prying tool underneath another metal prong on the metal face plate, as described in Step 1.
    • Again, gently tilt the prying tool to lift the metal plate.
  9. Motorola SURFboard SB5101 Metal Receiver Replacement, Lifting the Metal Plate from the Motherboard: step 9, image 1 of 3 Motorola SURFboard SB5101 Metal Receiver Replacement, Lifting the Metal Plate from the Motherboard: step 9, image 2 of 3 Motorola SURFboard SB5101 Metal Receiver Replacement, Lifting the Metal Plate from the Motherboard: step 9, image 3 of 3
    • Remove the prying tool and set aside.
    • Using one hand, gently grab the sides of the metal plate and lift away from the motherboard.
    • If the metal plate does not remove easily, tilt it as you lift the metal plate. If the metal plate is still attached, use the prying tool to detach more metal prongs.
To replace the metal plate, position it over the metal frame and gently press it down until it clicks into place.
3 other people completed this guide.
Cayce Rast
421 Reputation
3 Guides authored
Clemson, Team 1-2, Benson Fall 2014 Member of Clemson, Team 1-2, Benson Fall 2014
CLEM-BENSON-F14S1G2
3 Members
10 Guides authored
One Comment
Buen articul, solo recordar que mi compaƱia me dio con un sello en calidad de prestamo al servicio que contrate :(
Max Denis - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,780
