Motorola Talkabout FV700R Circuit Board Replacement
  1. Motorola Talkabout FV700R Circuit Board Replacement, Battery: step 1, image 1 of 1
    • Remove the back battery cover by pressing the tab to the left, and lifting.
    • A small screwdriver can aid this process.
  2. Motorola Talkabout FV700R Circuit Board Replacement: step 2, image 1 of 1
    • Remove the batteries currently in the radio.
    • When you're ready to add new batteries, place Ni-MH or AAA replacement batteries in the specified slots.
    • The orientation of the batteries is specified in the battery compartment.
  3. Motorola Talkabout FV700R Circuit Board Replacement, Volume Knob: step 3, image 1 of 1
    • Turn the Volume knob to the off position.
  4. Motorola Talkabout FV700R Circuit Board Replacement: step 4, image 1 of 2 Motorola Talkabout FV700R Circuit Board Replacement: step 4, image 2 of 2
    • Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
    • This may require some twisting and force.
  5. Motorola Talkabout FV700R Circuit Board Replacement, Front Faceplate: step 5, image 1 of 1
    • Remove the four 3 millimeter T6 Torx screws from the front of the radio.
  6. Motorola Talkabout FV700R Circuit Board Replacement: step 6, image 1 of 2 Motorola Talkabout FV700R Circuit Board Replacement: step 6, image 2 of 2
    • Remove the four 3 millimeter T8 Torx screws from the back of the radio.
  7. Motorola Talkabout FV700R Circuit Board Replacement: step 7, image 1 of 3 Motorola Talkabout FV700R Circuit Board Replacement: step 7, image 2 of 3 Motorola Talkabout FV700R Circuit Board Replacement: step 7, image 3 of 3
    • Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
    • Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna.
  8. Motorola Talkabout FV700R Circuit Board Replacement: step 8, image 1 of 2 Motorola Talkabout FV700R Circuit Board Replacement: step 8, image 2 of 2
    • Gently pull the circuit board away from the front faceplate.
    • Be careful not to tug the wire connecting the circuit board to the speaker, as it is still attached to the faceplate.
    • Do not touch the the button contacts on the circuit board (the button contacts are shown in the red box of the second picture). This can cause long-term damage to the radio unless you properly clean them (see Repairing Motorola TALKABOUT FV700 Two Way Radio Button Contacts Guide).
  9. Motorola Talkabout FV700R Circuit Board Replacement, Circuit Board: step 9, image 1 of 3 Motorola Talkabout FV700R Circuit Board Replacement, Circuit Board: step 9, image 2 of 3 Motorola Talkabout FV700R Circuit Board Replacement, Circuit Board: step 9, image 3 of 3
    • To remove the speaker from the faceplate, insert a paperclip through the front faceplate and push.
    • The speaker is glued to the front faceplate, so it may take some force to remove the speaker.
  10. Motorola Talkabout FV700R Circuit Board Replacement: step 10, image 1 of 3 Motorola Talkabout FV700R Circuit Board Replacement: step 10, image 2 of 3 Motorola Talkabout FV700R Circuit Board Replacement: step 10, image 3 of 3
    • Now the circuit board can be removed from the back faceplate.
    • To do this, grip the back faceplate in one hand and the antenna in the other. Pull and twist the antenna away from the back faceplate. The circuit board should be removed with the antenna, as they are attached.
  11. Motorola Talkabout FV700R Circuit Board Replacement: step 11, image 1 of 1
    • After pulling the circuit board away from the backplate, the result should be as shown in the picture.
  12. Motorola Talkabout FV700R Circuit Board Replacement: step 12, image 1 of 1
    • Remove all wires from the circuit board with a soldering iron.
    • Be careful when using the soldering iron.
    • Properly dispose of the old circuit board and solder the speaker onto the new circuit board.
Kayla Brennan
737 Reputation
6 Guides authored
Clemson, Team 6-4, Benson Spring 2014 Member of Clemson, Team 6-4, Benson Spring 2014
CLEM-BENSON-S14S6G4
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 1,580
