Motorola Talkabout FV700R Front Faceplate Replacement
  1. Motorola Talkabout FV700R Front Faceplate Replacement, Battery: step 1, image 1 of 1
    • Remove the back battery cover by pressing the tab to the left, and lifting.
    • A small screwdriver can aid this process.
  2. Motorola Talkabout FV700R Front Faceplate Replacement: step 2, image 1 of 1
    • Remove the batteries currently in the radio.
    • When you're ready to add new batteries, place Ni-MH or AAA replacement batteries in the specified slots.
    • The orientation of the batteries is specified in the battery compartment.
  3. Motorola Talkabout FV700R Front Faceplate Replacement, Volume Knob: step 3, image 1 of 1
    • Turn the Volume knob to the off position.
  4. Motorola Talkabout FV700R Front Faceplate Replacement: step 4, image 1 of 2 Motorola Talkabout FV700R Front Faceplate Replacement: step 4, image 2 of 2
    • Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
    • This may require some twisting and force.
  5. Motorola Talkabout FV700R Front Faceplate Replacement, Front Faceplate: step 5, image 1 of 1
    • Remove the four 3 millimeter T6 Torx screws from the front of the radio.
  6. Motorola Talkabout FV700R Front Faceplate Replacement: step 6, image 1 of 2 Motorola Talkabout FV700R Front Faceplate Replacement: step 6, image 2 of 2
    • Remove the four 3 millimeter T8 Torx screws from the back of the radio.
  7. Motorola Talkabout FV700R Front Faceplate Replacement: step 7, image 1 of 3 Motorola Talkabout FV700R Front Faceplate Replacement: step 7, image 2 of 3 Motorola Talkabout FV700R Front Faceplate Replacement: step 7, image 3 of 3
    • Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
    • Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna.
  8. Motorola Talkabout FV700R Front Faceplate Replacement: step 8, image 1 of 2 Motorola Talkabout FV700R Front Faceplate Replacement: step 8, image 2 of 2
    • Gently pull the circuit board away from the front faceplate.
    • Be careful not to tug the wire connecting the circuit board to the speaker, as it is still attached to the faceplate.
    • Do not touch the the button contacts on the circuit board (the button contacts are shown in the red box of the second picture). This can cause long-term damage to the radio unless you properly clean them (see Repairing Motorola TALKABOUT FV700 Two Way Radio Button Contacts Guide).
Jack Harrison
188 Reputation
1 Guide authored
Clemson, Team 6-4, Benson Spring 2014 Member of Clemson, Team 6-4, Benson Spring 2014
CLEM-BENSON-S14S6G4
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 705
