Motorola Triumph Camera Replacement
  1. Motorola Triumph Camera Replacement, Battery: step 1, image 1 of 3 Motorola Triumph Camera Replacement, Battery: step 1, image 2 of 3 Motorola Triumph Camera Replacement, Battery: step 1, image 3 of 3
    • Slide the back cover down.
    • Lift the back cover up.
    • Pry the battery out with the spudger
  2. Motorola Triumph Camera Replacement: step 2, image 1 of 1
    • Gently pry out the battery using the spudger
  3. Motorola Triumph Camera Replacement, Speakers: step 3, image 1 of 1
    • After removing the Battery remove the two screws with a T4 screwdriver.
  4. Motorola Triumph Camera Replacement: step 4, image 1 of 1
    • With the spudger, go around the seam of the phone and pry away the back chassis.
  5. Motorola Triumph Camera Replacement: step 5, image 1 of 1
    • Using the T5 screwdriver, remove all the four screws shown in the picture.
  6. Motorola Triumph Camera Replacement: step 6, image 1 of 1
    • Lift up the motherboard out of the device,
  7. Motorola Triumph Camera Replacement: step 7, image 1 of 1
    • Pry the speakers out using the plastic spudger.
  8. Motorola Triumph Camera Replacement, Camera: step 8, image 1 of 1
    • Locate the camera at the top of the motherboard.
  9. Motorola Triumph Camera Replacement: step 9, image 1 of 2 Motorola Triumph Camera Replacement: step 9, image 2 of 2
    • Use the the spudger to unclip the connector above the camera.
    • Remove the camera.
greg
12 Reputation
5 Guides authored
USF Tampa, Team 7-5, Leahy Fall 2014 Member of USF Tampa, Team 7-5, Leahy Fall 2014
USFT-LEAHY-F14S7G5
3 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 235
