Introduction
If your Motorola V190 cellular phone is unable to connect to the mini-USB cable, if your phone is unable to charge, or if the mini-USB port is loose, use this guide to replace the mini-USB port. The mini-USB port allows you to charge your phone.
While the mini-USB port—which is attached to the phone’s motherboard—is removed, be sure to clean the port using a compressed air canister.
Make sure to power down your phone before beginning.
Press the button at the bottom of the back cover.
Pull the back cover down.
Remove the battery.
Use the TR6 Torx Security Screwdriver to remove the four 6.3mm Torx screws on the back.
