Motorola V276 Keypad Replacement
  1. Motorola V276 Keypad Replacement, Battery: step 1, image 1 of 1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Motorola V276 Keypad Replacement: step 2, image 1 of 1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Motorola V276 Keypad Replacement: step 3, image 1 of 2 Motorola V276 Keypad Replacement: step 3, image 2 of 2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
  4. Motorola V276 Keypad Replacement, Motherboard: step 4, image 1 of 1
    • Use a spudger to remove the rubber plug from the upper left corner of the back of the phone.
  5. Motorola V276 Keypad Replacement: step 5, image 1 of 1
    • Use a Torx T6 screwdriver to remove the 4 screws that secure the back plate of the phone.
  6. Motorola V276 Keypad Replacement: step 6, image 1 of 3 Motorola V276 Keypad Replacement: step 6, image 2 of 3 Motorola V276 Keypad Replacement: step 6, image 3 of 3
    • Three tabs will hold the back plastic plate in.
    • To remove the back plate, pull the tabs towards the outside of the phone and lift the plate up simultaneously
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  7. Motorola V276 Keypad Replacement: step 7, image 1 of 3 Motorola V276 Keypad Replacement: step 7, image 2 of 3 Motorola V276 Keypad Replacement: step 7, image 3 of 3
    • Use a spudger to remove the ribbon cable from the motherboard.
    • Be delicate while removing the ribbon cable because it is slightly fragile and it is necessary for the phone to function
  8. Motorola V276 Keypad Replacement: step 8, image 1 of 1
    • Gently peel back the motherboard from the main part of the phone.
  9. Motorola V276 Keypad Replacement, Keypad: step 9, image 1 of 1
    • Peel back keypad starting from the top of the phone
    • You can clean or replace the keypad once you have removed it from the phone
Finish Line
Jonathan Cheung
1 Reputation
3 Guides authored
Cal Poly, Team 27-96, Amido Spring 2010 Member of Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 12
All Time: 952
