Motorola V325 External Casing Replacement
  1. Motorola V325 External Casing Replacement, External Casing: step 1, image 1 of 3 Motorola V325 External Casing Replacement, External Casing: step 1, image 2 of 3 Motorola V325 External Casing Replacement, External Casing: step 1, image 3 of 3
    • Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel.
    • Lift the panel off of the phone.
  2. Motorola V325 External Casing Replacement: step 2, image 1 of 3 Motorola V325 External Casing Replacement: step 2, image 2 of 3 Motorola V325 External Casing Replacement: step 2, image 3 of 3
    • Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
  3. Motorola V325 External Casing Replacement: step 3, image 1 of 2 Motorola V325 External Casing Replacement: step 3, image 2 of 2
    • Unscrew the four screws using the T6 Torx Screwdriver.
  4. Motorola V325 External Casing Replacement: step 4, image 1 of 3 Motorola V325 External Casing Replacement: step 4, image 2 of 3 Motorola V325 External Casing Replacement: step 4, image 3 of 3
    • Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
Minh Tran
2 Reputation
2 Guides authored
Cal Poly, Team 4-15, Forte Winter 2010 Member of Cal Poly, Team 4-15, Forte Winter 2010
CPSU-FORTE-W10S4G15
5 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 2,235
