Motorola V400 Main Screen Replacement
  1. Motorola V400 Main Screen Replacement, Removing Outer Shell: step 1, image 1 of 3 Motorola V400 Main Screen Replacement, Removing Outer Shell: step 1, image 2 of 3 Motorola V400 Main Screen Replacement, Removing Outer Shell: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the 4 stoppers surrounding the main screen with tweezers.
    • Use a Torx T-6 Screwdriver to unscrew the 4 screws around the screen.
    • Use a plastic opening tool to separate outer shell from metal interior cover.
  2. Motorola V400 Main Screen Replacement: step 2, image 1 of 2 Motorola V400 Main Screen Replacement: step 2, image 2 of 2
    • Use plastic opening tool to to separate inner metal cover from the circuit board. Apply pressure to remove the piece.
  3. Motorola V400 Main Screen Replacement: step 3, image 1 of 1
    • Insert black spudger beneath circuit board to pry it from phone screen.
  4. Motorola V400 Main Screen Replacement: step 4, image 1 of 1
    • Apply pressure to remove the screen from its adhesive backing on the plastic.
    • Place new screen on the phone.
Megan Brewer
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 258
