Motorola V551 Earpiece Speaker Replacement
  1. Motorola V551 Earpiece Speaker Replacement, Screen: step 1, image 1 of 3 Motorola V551 Earpiece Speaker Replacement, Screen: step 1, image 2 of 3 Motorola V551 Earpiece Speaker Replacement, Screen: step 1, image 3 of 3
    Tool used on this step:
    Spudger
    $3.99
    Buy
    • On the phone's face, remove the four rubber caps from the screw covers using a spudger.
  2. Motorola V551 Earpiece Speaker Replacement: step 2, image 1 of 1
    • Unscrew the four cover screws using a T6 Torx screwdriver, turning counterclockwise.
  3. Motorola V551 Earpiece Speaker Replacement: step 3, image 1 of 2 Motorola V551 Earpiece Speaker Replacement: step 3, image 2 of 2
    • Loosen and remove the protective cover using a plastic opening tool.
  4. Motorola V551 Earpiece Speaker Replacement: step 4, image 1 of 2 Motorola V551 Earpiece Speaker Replacement: step 4, image 2 of 2
    • Gently loosen the second protective cover with the plastic opening tool.
  5. Motorola V551 Earpiece Speaker Replacement: step 5, image 1 of 3 Motorola V551 Earpiece Speaker Replacement: step 5, image 2 of 3 Motorola V551 Earpiece Speaker Replacement: step 5, image 3 of 3
    • Carefully remove the protective cover from the circuitry.
    • Slowly peel the black rubber gasket off of the circuit board.
    • Carefully move the camera out of the way using your hand.
    • Use a flat tool to disconnect the upper and lower circuit boards.
  6. Motorola V551 Earpiece Speaker Replacement: step 6, image 1 of 3 Motorola V551 Earpiece Speaker Replacement: step 6, image 2 of 3 Motorola V551 Earpiece Speaker Replacement: step 6, image 3 of 3
    • Gently slip the copper strip out from under the circuitry by using your hand.
  7. Motorola V551 Earpiece Speaker Replacement, Earpiece Speaker: step 7, image 1 of 3 Motorola V551 Earpiece Speaker Replacement, Earpiece Speaker: step 7, image 2 of 3 Motorola V551 Earpiece Speaker Replacement, Earpiece Speaker: step 7, image 3 of 3
    • Pry out the speaker using your fingers.
gregatron
105 Reputation
6 Guides authored
Cal Poly, Team 6-6, Maness Fall 2009 Member of Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,744
