Motorola V551 Keypad Key Replacement
  1. Motorola V551 Keypad Key Replacement, Battery: step 1, image 1 of 2 Motorola V551 Keypad Key Replacement, Battery: step 1, image 2 of 2
    • Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
  2. Motorola V551 Keypad Key Replacement: step 2, image 1 of 1
    • Lever the battery out by pressing upwards on the bottom corners of the battery.
  3. Motorola V551 Keypad Key Replacement, Circuit Board: step 3, image 1 of 3 Motorola V551 Keypad Key Replacement, Circuit Board: step 3, image 2 of 3 Motorola V551 Keypad Key Replacement, Circuit Board: step 3, image 3 of 3
    • Remove the rubber screw covers using a plastic spudger.
    • Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
  4. Motorola V551 Keypad Key Replacement: step 4, image 1 of 1
    • Unscrew the antenna.
  5. Motorola V551 Keypad Key Replacement: step 5, image 1 of 3 Motorola V551 Keypad Key Replacement: step 5, image 2 of 3 Motorola V551 Keypad Key Replacement: step 5, image 3 of 3
    • Gently release the two latches using an opening tool.
    • The plastic latches are very fragile. Don’t use excessive force or they might break.
    • Pry off the back panel by wedging an opening tool into the crevice between the back panel and the circuit board.
    • Lift the back panel off of the phone.
  6. Motorola V551 Keypad Key Replacement: step 6, image 1 of 2 Motorola V551 Keypad Key Replacement: step 6, image 2 of 2
    • Loosen the copper circuit board connection with an opening tool.
    • Gently lift the copper connection.
  7. Motorola V551 Keypad Key Replacement: step 7, image 1 of 3 Motorola V551 Keypad Key Replacement: step 7, image 2 of 3 Motorola V551 Keypad Key Replacement: step 7, image 3 of 3
    • Lift up and pull out the pressure pad from under the buttons on the side of the chassis.
    • Gently lift the motherboard off of the front panel.
  8. Motorola V551 Keypad Key Replacement, Keypad: step 8, image 1 of 3 Motorola V551 Keypad Key Replacement, Keypad: step 8, image 2 of 3 Motorola V551 Keypad Key Replacement, Keypad: step 8, image 3 of 3
    • Push both side keys in so they are not sticking out of the phone.
    • Remove the keypad.
  9. Motorola V551 Keypad Key Replacement, Keypad Key: step 9, image 1 of 2 Motorola V551 Keypad Key Replacement, Keypad Key: step 9, image 2 of 2
    • Gently squeeze the bottle of super glue so that only a small amount (about 1/3 pinky width) is a applied to the back side of the key.
    • Be careful while applying the super glue as it can be quite strong.
  10. Motorola V551 Keypad Key Replacement: step 10, image 1 of 2 Motorola V551 Keypad Key Replacement: step 10, image 2 of 2
    • Carefully place key onto the key pad so that it will be properly oriented and in line with the other keys.
gregatron
105 Reputation
6 Guides authored
Cal Poly, Team 6-6, Maness Fall 2009 Member of Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 2,078
